Results 1 to 4 of 4
Thread: cleaning up VL
    VT S Pack
    Apr 2011
    Question cleaning up VL
    hey guys
    my friend has a VL Wagon N/A and we are going to be selling it soon
    just wondering if any of you guys know how to put the 2 front door interior handles together again
    the handle has broken off
    heres a picture of where it's broken (it keep falling out of the hole)
    what's the easiest way to fix this, thanks!!
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    EDIT: totally wrote a write up on the wrong part, give me a sec >_<
    Ok, so basically, that style handle looks the same as the ones I have in my ute:
    And, I think you're referring to this part, the handle screws twice into the main arm rest, and once at the top of that thin handle, and with all 3 screws, they go all the way into the door card, and into the actual metal of the door. You could try screwing a metal plate to the inside of the door (under the card) so when you screw the handle into the door, it screws into the metal plate instead of the original hole (which sounds as if it's widened or lost it's threading)
    |8|7|R|B|3|0|V|L|
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    there is a plastic lug in the door that by the sounds of it YOURS is F@#$*D! or you have the wrong sized screw in the hole, try a larger screw or you will need to remove the door card and replace the lug. or you could inject some ARYLDITE epoxy glue into it jam the screw in and leave to set for 24hrs, then sell the car.
    I would replace the lug.
    Nobody wants to play with me
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by jatsvl View Post
    What he said :P
    |8|7|R|B|3|0|V|L|
  1. Cleaning the IAC
    By joshy123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2012, 06:45 PM
  2. Cleaning MAF
    By pk2k78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-06-2009, 06:52 PM
  3. Car cleaning..
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-10-2006, 01:31 PM
  4. Cleaning you car - What do you use?
    By Indy_387 in forum General
    Last Post: 25-07-2005, 03:23 PM
  5. Car Cleaning
    By Troy711 in forum General
    Last Post: 23-01-2004, 12:08 AM
