Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Sik_Cordz
Thread: Vl Not Pumping Fuel
    Vk 5LTR
    Oct 2007
    Melbune
    Default Vl Not Pumping Fuel
    hey guys ive having a problem with my vl pumping fuel.ive checked both intank and ext pump and both work and both have power. but it seems nothing is coming from the tank. there is around 25ltrs of fuel. no the car has sat for 3years so is it possible somthing is stuffed inside the tank ???
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    did you take the hose off the pump/s and check they are pumping fuel and not just buzzing?
    if so I would be looking at the fuel filter being blocked or fuelines to the engine blocked, kinked or crushed.
    Nobody wants to play with me
    Vk 5LTR
    Oct 2007
    Melbune
    i took the hose directly of the intank pump to check for fuel and nothing.
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    there is a little filter bag on the end of the internal fuel pump, if the car has sat for 3yrs then could be covered in crap in the tank.
    Vk 5LTR
    Oct 2007
    Melbune
    the intank pump came out of a running car.so i dont think its that.im taking it out anyway just to check. but i guess the next thing might be to flush the tank out
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    On my 83 Mazda B2000 (F-rd Courier) it had been sitting for over 10 years in a paddock, and when I got it, I managed to get it on the trailer but I had to swap the fuel filters under the tray & under the hood because it was trying to pump fuel but the filters were blocked so it would just die on startup. Then again, it's carby fed so I dunno
    |8|7|R|B|3|0|V|L|
    Vk 5LTR
    Oct 2007
    Melbune
    it cant be the filters as ive just disconnected the lines so its only coming out of the intank pump. could a blocked reurn line cause the problem, i can see i might have to drop the tank and flush it out
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Ah true sorry, let us know if you do end up dropping it
    |8|7|R|B|3|0|V|L|
    Vk 5LTR
    Oct 2007
    Melbune
    Vk 5LTR
    Oct 2007
    Melbune
    worked out the problem. i didnt have the pump sitting right inside the tank .so its getting fuel now
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    yeah lining it up in the swirl pot can be tricky on some cars. all good man nice work
  1. VL V8 commodore not pumping fuel
    By Arrowroot in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-04-2011, 11:33 PM
  2. vl not pumping oil
    By madd50 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-07-2009, 12:32 AM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. Not pumping fuel
    By leslloyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-12-2008, 02:57 PM
  5. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
