Results 1 to 9 of 9
Thread: Vlt LPG conversion.
    WK statesman 5.7, VS exec TURBO
    Sep 2005
    mornigton penisula VIC
    Default Vlt LPG conversion.
    Hi guys. I'm putting a standard turbo setup on my vl. I'm also building a low comp engine to handle about 25 PSI and I plan on running strait gas with a gas research system.
    I'm using this motor to get my gas system sorted out and my ignition system and then a cooler all ready for the new motor so I can just put the motor in and run it.
    But I'm going to use the rebate to get the basic setup in with an impco setup or something similar until I have my manifold and cooler and piping ready for the gas research system.
    I was just wondering where will they put the mixer? Will they remove the cross over pipe and make a new one? I'm just curious. Also what mixer would you recommend?
    Road trawling paddock bomb = moody VL
    Jul 2009
    goldfields VIC
    you wouldnt rather make life easier for later and start with a gas research tb?
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Much like a fuel system - an LPG system to support the power you'll make on 25psi is different to the system you'd use to power a stocker vlt setup.
    Ignition on an LPG car will also be very different on 25psi to a standard setup....
    Setting up a system suited to a stocker isn't really going to "get it sorted" for your new motor. - You'll need to change lockoffs, add another converter, re-route a bunch of gas lines, water lines, balance pipes, etc......
    The GRA setup also runs different converter springs and a different closed-loop setup to your avg impco setup (or a mixer-ring setup, for that matter).
    So in short - everything from your LPG tank forward will have to change.....
    Money, time and stuffing around wise - you'd be much better off just doing a full GRA setup with two converters straight up - if the end goal is a 25psi engine....
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Can the vapour system and go liquid injection. It will shit all over the power you will make on vapour. Do it right the first time and you will have a very quick car.
    Visit my Facebook page
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    will require some form of ecu upgrade as well swapping to gas so you can tune spark properly
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Google GAS747. And read his specs on his gas vlt that thing absolutely HAMMERS
  1. holden vs v6 to a vs v8 conversion/ or a l67 conversion
    By JLOWE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2011, 10:52 AM
  2. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  3. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  4. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
