Results 1 to 5 of 5
Thread: fuel injection and water 2 questions
    vl berlina wagon 6cyl
    Jul 2005
    Default fuel injection and water 2 questions
    when fuel injection came in people said an injector could partly block, causing a weak mixture in a cylinder so that cylinder would overheat and burn out the exhaust valve without any warning of a problem
    has this ever actually happened?
    next, what happens with water in the fuel, is there any water trap in the system or any way to drain the water in the 6
    vy2 clubsport
    Feb 2008
    adelaide
    very hard to get water from fuel tank into motor.
    water seperates itself from the fuel like oil does in the ocean when you see an oil spill.not sure if it floats on top or on bottom.im sure it sits on bottom so very very unlikely it would go into engine as when you run out of fuel im sure you would still have 3mm or so of fuel stil left in tank
    also from memory petrol stations have water in there tanks under the bowsers for some reason i cant think why it was thoe
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Any fuel with ethanol in it will cause any water in your tank to mix with fuel so it is burnt in your engine. People used to use a cup of metholated spirits in their fuel tank to make water mix with fuel so it didnt rust out your fuel tank and cause fuel blocks. If one of your injectors blocks up you will know, because it will run rough at idle.
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by harry3 View Post
    Yes, it would cause it to run lean.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    if ur worried stick to carby and hope your jets dont have a block :P:P
  1. water injection
    By kniever in forum General Discussion
    Last Post: 02-09-2009, 08:19 AM
  2. water injection
    By eaton v8 in forum V8 Development and Modification
    Last Post: 14-04-2009, 02:25 PM
  3. water injection
    Last Post: 28-05-2008, 06:33 AM
  4. Vk DIY water injection
    By AuWozza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2005, 05:20 PM
