Results 1 to 18 of 18
Thread: VL problems. fuel filter?
    VS statesman
    Nov 2010
    melb
    Default VL problems. fuel filter?
    ok so was driving for like 15 mins.
    engine stopped.
    then wouldnt start again.
    then after 5 - 10 mins it would start then stall again.
    the longer i leave it sitting there the longer it will run for.
    possible fule filter?
    starving of fuel?
    i dont think its the fuel pump as i can hear it working.
    if you think it is the fuel filter, a link to a step by step fix would be appreciated
    My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
    WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Check for codes. Could be CAS.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    2nd the CAS methinks, spesh on a VL
    |8|7|R|B|3|0|V|L|
    VS statesman
    Nov 2010
    melb
    ok thanks guys, just got it home. how much we talking for a new CAS?
    i just drove it home from where it broke down. it ran really nice, is there any way to tell if its the CAS?
    because i want to be sure.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VS statesman
    Nov 2010
    melb
    how much is a CAS? because ill just replace it.
    how long would it take to replace?
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    cas, next time it stops try pouring a cold drink on it, coke, water whatever lol, and if it fires up again that preety much means its farked. I have a few lying around the shed, shouldnt cost to much for one from a wrecker.
    VS statesman
    Nov 2010
    melb
    ill try source a cas through my work tomorrow. so it should be reletively cheap.
    still how long will it take to swap over?
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by mattstatesman View Post
    I deliberatly didnt answer that question, becuase ive never done it and wouldn't know lol, all i can say is i pulled one out of a wreck in 5 mins. Detox nath should be able to give you a answer
    vl berlina wagon 6cyl
    Jul 2005
    look under car for any long length of rubber fuel line, when warmed by air coming back from motor it can kink shut, then after a while it cools and unkinks, until the next period of hot running when it kinks shut again,stopping engine happened to me
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    about 10 mins when u know how to do it.....
    follow my thread in my sig and make sure u dont flip the metal disk and keep it really clean/..... u will c about this disk in my thread......
    i would think for u about 20 mins.... judging on your knowledge... its not hard at all.
    VS statesman
    Nov 2010
    melb
    ok so all i did was wiggle around the 2 main wires going to the distributor and now its running fine?
    anyone else found this?
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Possibly the dizzy is on it's way out? or whatever that thing is inside it that fails?
    |8|7|R|B|3|0|V|L|
  15. #15
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    thats the CAS which is inside the dizzy... so unplug the main 4 pin plug and check the spade connectors.. spray some Rp7/INOX/ etc in the plug and reconnect.... as well as inspect the wires on the plug(top plug) under the rubber boot where the wires are crimped on.. they can corrode off
  16. #16
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Lol I had such a brainfart just then since a few posts ago I mentioned I seconded the comment that it's the CAS, god I need to go to sleep early tonight
    |8|7|R|B|3|0|V|L|
  17. #17
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  18. #18
    VS statesman
    Nov 2010
    melb
    very helpful guys, thanks.
  1. VE 2007 omega oil filter problems
    By SnowyGT in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-02-2011, 07:57 PM
  2. Fuel Filter and Fuel Line
    By King_berald in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:51 PM
  3. Fuel filter removal problems
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-01-2010, 02:53 AM
  4. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  5. Fuel Line removal tools for Fuel Filter
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 09:56 PM
