hey guys, i have fuel pressure running to my injector rail and i have injector pulse just dont seem like i have fuel geting in the chamber, but if i spray start ya bastard or degreaser in the air intake the car will start and run.. any queries people please???
if it keeps running on petrol perhaps you arent waiting long enough for the main pump to buuild up fuel pressure
blocked injectors??
Simple enough to see if the injectors are working.. Remove them from the intake still attached to the fuel rail and turn the car over.
yes i got fuel pressure will be checking injectors now thanks guys
have u run a diagnostic on the ecu..? pull the codes..
could be a corroded ecu pins as well
water gets in down under the windscreen as aussie-macca just had this problem tried another ecu and it worked
