Results 1 to 5 of 5
Thread: rb30et fuel issue.
    vs ss manual
    Jun 2011
    camira
    Default rb30et fuel issue.
    Got an rb 30 with full turbo conversion in a 280z. Had it dynoed to see eat power it put out. It's got standard turbo ecu, injectors, turbo manifold, turbo, and the guy said the fuel map was off the chart wen dynoed. They thought it was fuel reg. Fixed. Bigger fuel pump indtalled and still can't fix it just runs real rich and dont know y
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    vs ss manual
    Jun 2011
    camira
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    well blocked filter starves the engine of air.. meaning rich
    coolant temp sensor failing = engine ecu thinking the motor is still cold and runs a rich mixture..
    o2 sensor failing = Ecu trying to measure hot or cold measurements and uses this information in closed loop to run a lean or rich mixture,..(fine tuning)
    XR6T, sorry
    Nov 2010
    Carrum Downs
    Being a MAF based system a blocked air filter should have less effect. Is it only rich under power? If idle, cruise and cold start are OK. If its rich everywhere then yeah, coolant temp sensor, high fuel pressure (non-genuine reg setting or faulty) Have you made any mods? Intercooler? Where is the MAF, stock location. If the MAF is in the stock draw through location and there is a boost leak it will go very rich. You can tune the Factory ECU with Nistune if there are no other issues to be found.
    Joel
  1. vr fuel issue.........
    By shaneo vr355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2009, 07:05 PM
  2. Fuel issue
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2009, 07:18 PM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
