Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Running Rich..?
    87 VL Calais Turbo
    Mar 2009
    Default Running Rich or fuel leak??
    Hey there,
    On saturday i went and picked up my new VL
    Just been keeping an eye out for any problems that may occur and i can smell a fairly strong petrol smell as if the car is running way to rich... Im new to VL's and dont know much at all so im asking for help here! haha
    From what i know, its a VLC turbo with an n/a conversion (p plater friendly)
    Ill get a "my car" thread going soon enough :P
    http://i.imgur.com/H3AQZ.jpg
    Cheers and hope u can help...
    UPDATE:
    So i have now fixed my exhaust leak and blown dizzy and its honestly running like a brand new car. But the fuel smell is still there, maybe even worse. MOST of the time you can small it fairly strong inside the car and sometimes can even smell it when standing outside the car after driving.
    My fuel usage is much higher than it should be.
    UPDATE 2 - ERROR CODES!
    These are displayed (along with the others that are meant to be)
    11 Crank angle sensor circuit
    12 Air flow meter circuit
    21 ignition signal circuit
    ANY IDEAS/SUGGESTIONS???
    UPDATE 3!
    Found where the fuel is coming from! Im not all that great when it comes to engine work but from what i can see the injectors are all surrounded by leaking fuel. Enough to cause the smell that is getting me high on my hour long drive to work! Here is what im talking about:
    I also following the guide on how to adjust your AFM and i turned the screw half a full turn clockwise to try make it leaner. Did not really make a difference though?
    Took another pic for you
    http://i.imgur.com/6ldWb.jpg
    More pics in sunlight and of interior yet to come lol
    I build websites for cheap.
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    My car usually smells like petrol sometimes, but not too often that I worry about it. It runs fine regardless so I don't think anything is up. Is your smells always there?
    |8|7|R|B|3|0|V|L|
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    87 VL Calais Turbo
    Mar 2009
    Well yea it gets pretty strong, and there is a fairly noticable leak/hole in the exhaust up near the headers which is causing some problems (im hoping thats the cause, if its not i wont be happy haha). Once i pay rego ill patch it up and go from there i guess.
    Thankyou, i cant wait for CFC this year haha!
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    re-reading your post, I wonder if it has anything to do with the turbo-to-NA conversion that was done on it? I don't know much about fuel injection, but could it be possible that there were larger injectors installed, and once the turbo was removed etc, the injectors are squirting too much fuel in?
    See if it was a carby I could probably sound like I knew more since I know more about carbies :P
    |8|7|R|B|3|0|V|L|
    87 VL Calais Turbo
    Mar 2009
    It is fuel injected, and i THINK he put an NA engine in, rather than removing the turbo from the existing engine. I really need to obtain more details when purchasing cars haha. Well ive withheld the last bit of the payment untill he gets a few things that he promised so next meet up ill get what info i need haha then update my post.
    VB SL/E
    Dec 2008
    Quote Originally Posted by swiftymcfeat View Post
    What colour is the exhaust?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    search the forums for running rich man... its been covered plenty of times....
    nice car love the color...a few things can cause running rich problem...
    it could be the vapour lines from the fuel tank have split hence the strong petrol smell... have a sniff in ur boot and around your back seat/behind rear wheel under the guard,,, i wont call u an abo either,
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    petrol smell is usually as detox_Nath has said around the back of the car near the wheel arch, it could be vapour lines also if it is in the engine bay check your fuel in and out lines also the little rubber hoses to your injectors.
    Nobody wants to play with me
    vy2 clubsport
    Feb 2008
    adelaide
    87 VL Calais Turbo
    Mar 2009
    Purple with blue pearl through it mate. Ill get some better pics up with time haha
    87 VL Calais Turbo
    Mar 2009
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    so if the smell is inside the car I would suggest it is in the engine bay, so you need to check all the fuel lines and follow your nose, the smell will get stronger the closer you get to the source.
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Check too see if its running 3ta or 3tm ecu. My bets that he has ripped the turbo off and put n/a headers on it. What colour are the inectors? They will either be brown or a tan colour
  15. #15
    87 VL Calais Turbo
    Mar 2009
    Quote Originally Posted by VL_5SPEED View Post
    Ill check the headers tonight after work, but im fairly certain he did an engine swap and put the NA engine in rather than just removing the turbo. I suppose he could have left the old ECU, i mean he did not bother putting the heater or air con back in at all haha
  16. #16
    87 VL Calais Turbo
    Mar 2009
    Had a sniff around the engine and it just smells too strong to know where its from... Im fairly certain its coming from somewhere towards the back of the engine. I gotta figure it out im getting headspins!!
  17. #17
    87 VL Calais Turbo
    Mar 2009
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    set ur afm back to factory so u dont get a lean out... have u fixed your leaking injectors?...
    these codes "could" be old codes stored so clear them and run a diagnostic again..
    go over all your plugs/sensors and give them a shot with INOX/Contact cleaner/WD40 etc even pull back the rubber boots and check for corrosion on the crimped spade connectors... then process of elimination man
  19. #19
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    all of your injector hoses and clamps have been replaced go over them with a flat head screwdriver and tighten them up that will probably solve your fuel smell.
    people usually replace them when they replace INJECTORS.
    edit; your cooling system bleeder bolt has corroded and snaped off, so whats in the hole?
  20. #20
    Pub247's Avatar
    Pub247 is online now Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    air flow meter almost always cause rich lean running as they tell ecu how much air there is and then ecu put in x amount of fuel so if AFM reads more air than there is then ecu will put in more fuel than needed.
    Get that leaky injector fixed too looks like the hose from rail to injector is leaking
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  21. #21
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    good spot justo... looks like the bolt thread is still in there
    so not good cant bleed that high spot only one on the plenum....
    make sure u fix this man
  22. #22
    87 VL Calais Turbo
    Mar 2009
    Will be replacing every hose and clamp along there 2moz. One doesnt even have a clamp! Hour drive home i swear im high as ####!!!
    Ill keep u posted
    Thanks all!
  23. #23
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
  24. #24
    87 VL Calais Turbo
    Mar 2009
    Thanks for that! My silivour tastes like fuel! Bleh!
  25. #25
    87 VL Calais Turbo
    Mar 2009
    All injectors and hoses to injectors got replaced today. Running great! Got half way home, starts running rough, and dies. If i start it its like its running on 1 cyl. Now im stuck on m4 waiting for a ####ing tow!
  1. 304 running rich
    By aidanhq in forum General
    Last Post: 22-11-2010, 07:09 PM
  2. vp running rich
    By blockhanson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2009, 07:29 PM
  3. Running Rich Y?
    By CNULTR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-03-2009, 01:25 PM
  4. VN running very rich
    By 333 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 06:42 AM
  5. VN 5L running way too rich
    By vkberlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2005, 12:32 PM
