Results 1 to 3 of 3
Thread: welch plugs
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default welch plugs
    quick question, do i just bang in welch plugs? or is there some type of glue used? cheers
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah you should use a sealant. Any kind if gasket glue or aviation glue will do. Just remember to use a socket the same size as the O/D of the plug. Not one that fits snug on the inside otherwise you could end up bending it out of shape.
    [edit] or knock them into the block with a bit of timber like this bloke has http://www.youtube.com/watch?v=iTIEt...eature=related
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    a good sealant is STAG.....
    but yeah second that use a socket the same size and carefully knock it in... depends on what ur doing if ur taking other pieces off the engine to be able to change it use your noggin and do all that u can get too.. as u know they r the same age/ corrosion level and will all eventually fail... so for piece of mind do it then :P
  1. welch plugs
    By freeway29 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2010, 01:20 PM
  2. where are the welch plugs
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-11-2008, 04:25 AM
  3. welch plugs, where are they, who's done em?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2008, 08:09 AM
  4. Changing Welch Plugs
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 02:08 AM
  5. VN welch plugs
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 05:52 PM
