VL Nissan 6 ,where do I grease chassis on vl? eg grease nipples on front end?I already know how to change engine oil.cheers
there are no grease nipples, the ball joints and tie rod ends are sealed and the rest of the suspension is rubber bushes if they are sqeaking then they may need to be torqued up or replaced you can get RUBBER grease and apply it to the bushes but that will just mask the problem, ontop of your struts there is a large bearing which you can apply bearing grease to relatively easily.
Nobody wants to play with me
