Hi Guys,
I have a VL Commodore Berlina auto. Its winter here now and each morning when I drive to work I accelerate around a corner and its like the Engine Revs but it does not drive the car. Its like it pops into neutral, I easy off and then it slips into gear.
It seems to do this mostly in the cold mornings and when the engine is cold.
What could the problem be? I'm guessing Oil could be leaking somewhere onto the fly wheel / gear box and causing it to slip until its warmed up?
Thanks.
Sounds like your oil level is low check its right and get back to us
Sent from my Samsung galaxy GT-I9100 using Tapatalk
mines doing the same.... but with 10.psi through an NA its a given eventually...
mate it could b oil level, worn clutches, etc etc
