Results 1 to 7 of 7
Thread: vl fuel problem i think???
    vb sle
    Jan 2009
    adelaide
    Default vl fuel problem i think???
    i have a problem with my new vl i thought it was the fuel pump but changed it and is still doing it it start and runs then dies then wont start if you leave it for awill it will start but just dies any ideas it semes like a fuel problem but may be wrong any help will be reatly apreciated cheers
    vb sle
    Jan 2009
    adelaide
    also its a 5 speed and it wont stay in 2nd unless your powerin on if you drive it like a bi#$h it jumps out have brought some nulons treatment but want to change oil aswell how much does the 5 speed hold 2ltrs????
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Have you checked to make sure the fuel lines aren't frayed or pinched/blocking fuel? Also, could be the CAS. I swear someone recently posted a thread with these symptoms..
    If you need it, read THIS ARTICLE Detox Nath posted, cos' it's probably the problem
    |8|7|R|B|3|0|V|L|
    vb sle
    Jan 2009
    adelaide
    yea just been lookin round and seen that tread sounds exacly the same my mate that i brouht it off of has had the cas replaced but is suppost to be a common problem ill change it and see what happens cheers
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    sound exactly like a CAS problem.... when they r failing they will do this as they get warm and once cooled will be ok again.....
    when u changed your pump which one was changed as there is 2 (inertia in the tank sits in the swirlpot) and the highflow pump sits on the outside of the tank
    vb sle
    Jan 2009
    adelaide
    the high flow one also i think its the regulator the one just befor the fuel pump
    vb sle
    Jan 2009
    adelaide
    hahah people remember when you clean your engine and it breaks down check for water it ended up being water in the plug of the cas what a noob
  1. vn vp low fuel problem
    By vn88holden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2011, 08:44 AM
  2. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  3. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  4. fuel problem
    By reggie_c2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2008, 05:44 AM
  5. Fuel problem
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2006, 03:18 PM
