Results 1 to 8 of 8
Thread: VL diff problem
    The V-HELL is offline For the love of VL's
    VL Berlina
    Feb 2011
    Alstonville
    Default VL diff problem
    Hey guys I have a bit of a problem with my old VL.
    The problem is if I leave the car in 1st and gear park it ( ie turn the car off with the clutch in) when I start it up again an then put it into reverse the gears don't engage with the diff until the clutch is almost completely out and when it does engage it clunks and goes in pretty hard. I don't know if it's the gearbox or the diff.
    Any ideas?
    stuntmanmike's Avatar
    stuntmanmike is offline Car wotsit & stuff
    VP 3.8 V6 Auto and VS BT1 5.0
    Jun 2009
    At home on planet earth...
    Sounds like your linkages on the gearbox for 1st gear and reverse gear need adjustment. When was the last time you changed the oil in the transmission or had it serviced?
    VL Berlina
    Feb 2011
    Alstonville
    It was serviced not too long ago but I dont have any record of a gearbox oil change in the invoice. I might see if I can get it changed in the next few days
    Jun 2009
    It might be normal considering that the reverse gear does not have synchronisers (aka synchro rings). Without knowing what the extent of the "clunk" is maybe you could gear park the car in any other gear other than 1st and see if the same issue occurs when you attempt to engage reverse.
    In my experience, all the gears should engage smoothly. If not then it would be best to start by looking at the clutch/throw out and the shifter/linkages. You say that your gearbox was serviced not too long ago so I'm kinda at a loss if something changed between the service and since you discovered the issue. I hope that it is something simple and doesn't cost too much to rectify. Tricky to diagnose through the forums...
    What's the "stick feel" like when the engine is off and you run through the gears without the clutch being actuated when the car is on a flat and level surface?
    VL Berlina
    Feb 2011
    Alstonville
    Yer it goes through the gears no worries when parks on a flat without the clutch, I tried it gear parking it in 2nd and 3rd and still had the same problem
    VL Berlina
    Feb 2011
    Alstonville
    just to conclude this post for others who may experience this sort of problem.
    i took the car to a mechanic and it turns out it had nothing to do with the gearbox.
    the real problem was with the handbrake and rear drums. both drum cylinders were leaking alittle and one of the handbrake cables was siezed and catching.
    the clunking backwards was the handbrake cable freeing itself slightly releasing one of the rear drums.
    the gearbox is all good and running well
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    OK, so the gearbox was actually going into reverse, just the noise was coming from the back when it started to move.
    Your initial explanation sounded like it wasn't going into reverse until the clutch was just about all the way up. But after reading the solution, this is actually a fairly common problem.
    Visit my Facebook page
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    time for a disk rear upgrade...
    easy and a cheap way to upgrade for the better...
  1. vz diff problem
    By donf in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-02-2010, 11:10 PM
  2. VT Diff Problem
    By VN_Bucket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 07:33 PM
  3. Vt Diff Problem
    By HSV_LS1_VtRRRRR8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2005, 08:34 AM
  4. Diff Problem
    By sikvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 09:21 PM
