so i have noticed for a while now that i dont have as much power as i would say medium revs (havnt got a rev meter) or its about the same as high revs not much pick up at all. are all vl's like this or have i got a problem with injectors or the fuel pump or something?
Has it always been like this or has this just happened? It sounds like a normal stock N/A VL commodore to me!
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
im sure its always been like this but wouldnt be to sure since i have had the car for about 3 or 4 months. its running better then ever after getting a thermostate that works and the rite spark plugs after auto barn gave me the wrong ones >:I but once i think about it i dunno if i hear the wine of the fuel pump when i start my car not sure if i got used to the noise or not but yer
i get a whine noise from my pumps as well.... lack of top end could be a few things
poor timing....
blocked exhaust(cat converter) sometimes the honeycomb /porceline crap breaks and blocks your pipe....
I sure as hell hear mine, it's a brand new one and it whines more than a wife after 10 years of marriage!
But yeah I have an auto NA and mine has no top end balls. My bro has a 2.0L 6 cyl BMW and off the lights I smoke him but if we're going, say, 60km/h, and we both plant it, his leaves me eating rubber
|8|7|R|B|3|0|V|L|
haha good one 87RB
and yer could be my cat i hear the honeycomb can melt after your car has been running rich to long wich mine has been since i got it dunno how much off that is true tho.
should i just knock it out or get a new one any suggestions? cheers for the info
n also my timing was out by a bit but fixed now so i dont think it will be that
and just a random question how long have you guys owned a vl for?
wowaweewa stuff payin that! guess its another thing to buy with the money i dont have haha
is there any point of getting a hi-flow cat for a non turbo vl with a cat back exhaust? and a rough price would be good...thanks
There not that expensive a couple of hundred if that, even a second hand one that decent will do for a while.
I only paid $200 for a hi flow cat for my Silvia, actually I think it was a bit cheaper.
I've only owned my VL for a couple of months but I love it to bits, as long as it doesn't fall to bits :P
|8|7|R|B|3|0|V|L|
another thing ill have to get when i can.
cheers for the help
Get a crow cam
nope u will c minimal gains with a cam on a n/a then u will get used to it and think u have lost power again...
running rich wont melt the cat but it will be sooty exhaust and eventually block the small pores of the inners of the cat. hense blocking it up
set ur timing to 15degrees (factory)
get a 5 spd manual and a good exhaust...
then possibly advance timing and run 98 fuel..
ive had 2 vls 11 years now with vls(all i have had)... me personally the shape of the vl is the best... smart looking car once all done up...
have great strong motors and turbo kits readily available to spice it up and see noticeable amount of performance...
That's what got me onto them, I love the shape of them, especially the lip on the boot. These cars just need a new paint job and they look 1000 times better haha, hell, if I dropped mine and resprayed it, no one would know, just from looking, that it's pretty much stock inside.
|8|7|R|B|3|0|V|L|
there are four bolts holding your cat on, remove them and drop your cat out (it is an easy job) hold your cat up to the sun and look through the other end, you should be able to see a bit of light, if you can't see light it is blocked. if the honey comb is brocken or missing , replace your cat with a good secondhand one or an aftermarket one for about $180 install it yourself with 2 new gaskets or pay about $85 for labour, genuine are EXPENSIVE.
cams are a waste of money on a stock NA
I have owned 2 vl's for driving 1 sedan now wagon in 9yrs, I have owned 7 more for stripping repairing and selling. my car before was a VK, needless to say I am never going back.
Nobody wants to play with me
well what type of mods could achieve more top end power? would be best if these mods could be used for when i turbo it but yer any suggestions are good. since turboing it will have to wait till im off my p's.
I've owned around 11-12 vls over the past 10 years. There's nothing you can really do to make it go all that better really its a n/a you'll have to drop an 8 in it or turbo.
what makes you guys get rid of vls and them get another? and yer so iv heard it takes big money to get a reasonabley fast n/a
because i am an idiot and like waisting money
ha fair enough is the one in ur display picture the one you got now?
would lighter pistons conrods ect help with top end power?
I sold it about 3 months ago or near abouts. Your best bet is to just save your $$$$ and spend money on an ls1 or turbo setup once your able to.
Yeah, a NA RB30 isn't worth the effort past an exhaust, turbo setups are about 1100ish from memory for a stock setup. A 304 would be alright as well because the VLs being light its a good combination.
