hey guys having some issues with my high beams and indicators
my indicators when turned on only stay on don't flash. but when i put the hazards one there flash. thought id start with replacing the flasher can . but still same thing
high beams just are not working. the low beams work but when i try engage the high beams the low beams cut out and nothing from the high beams
Checked your fuse box? High beams usually always go on VL's, mines all nice and fried up in the fuse box. That'd be the first place I'd check!
|8|7|R|B|3|0|V|L|
ive checked it and notice that both low beam and high beam fuse have melted and someone has wired in two need fuses. maybe the high beam fuse is gone. didn't get to much checking done, will have a better look tomorrow.
Let us know if you notice anything suss in there
|8|7|R|B|3|0|V|L|
also u get very erattic behaviour if the plugs on the lights themselves as in the large loom plug for the whole light setup either side.(not the individual globe plugs)
i had crazy problems like yours which is was my left plug was a bit loose. unplug them and spray in some inox/wd40 etc and c how u go.
let us know your outcome...
if not either of the things mentioned it could be your switch itself..
i just replaced mine5 days ago in less than 10 mins and cost me $25
well guys had a bit of a result. highbeam fuse was stuffed . replaced it and there working. indicators still not working, is it worth replacing the stalk ?
have u tried the main plugs at the lights
the whole assembly plugs into
as i stated above..
other than that try another stalk from a mate first
yer im gonna try a different stalk tomorrow and ill inspect the connectors
