Results 1 to 11 of 11
Thread: boot release
    kunifa Guest
    Default boot release
    my car caughgt fire and the battery melted. i think i have locked my keys in my boot and cant unlock it becoz the only key that opens my boot is in there (i think) so my question is.....
    where would i find the cable that runs to the boot release solenoid.
    i have a 12 volt transformer and i have been messing around with the cables under the back door on the drivers side. it says in the wiring diagram that the cable is black. i have found that one of the m is the external fuel pump and there are still 2 more and nothing happens when i earth it to the body. could this be because the negative cable runs back to the engine bay (where the fire was) and has melted it off or sumthing. i have also tried to put power through the swithch in the glove box but it didnt work. i just want to know whrere the cable for it goes so i can get my keys out and take my tail lights out so i can sell them.
    thanks alot
    chris
    VR Berlina V6
    Sep 2005
    orange
    You will need to power up the wire you found under the drivers kick panel, so for this you will need to replace the melted battery. Be very cautious she doesent go up again, god knows what your engine bay wires are like, just sit the terminals on the battery, dont tighten them, this way if it turns sour you can quickly remove a terminal.
    kunifa Guest
    i really dont think u know how bad the fire was
    http://photobucket.com/albums/y170/kunifa/
    it melted everything under the bonnet and i dont have another battery sitting around, so that means i would have to get one out of mum or dads car which is just a pain in the ass.
    i really just want to stick this 12 volt transformer in sumwhere and earth it to the body and hope it will pop open. i have cut all the black wires that run under the passenger rear door so if it is one of them it wont work anymore.
    i just need to know if one of hte black wires i have cut is the boot release or if it is sumwhere else. mayb my transformer doesnt have enough power ( i only assume it is 12 volts. it is from an old ikea light that broke and has nothing written on it that indicates the voltage.
    rattattack1313 Guest
    Cool
    I would be REALLY careful putting any sort of power into that mate.........how on earth did that happpen???? and NEVER assume anything with electricity.......get a multimeter and check the output.....
    kunifa Guest
    i opened it. i used a 12 volt battery drill batter coz that is ac not dc like the transformer i was using. it was one of the three black cables under the drivers side door.
    th only problem is now, WHERE ARE MY KEYS????
    they wernt in there
    VR Berlina V6
    Sep 2005
    orange
    Sorry dude, after reading your post again it seems I done the old lazy read, lot clearer now, It should be just 12V straight to the solinoid and it earths itself to the bootlid via the mounting bolts, make sure your transformer is DC (not AC).If all else fails remove the back seat.
    Mar 2005
    doesnt look like keys are ur problem... no point havin keys with an engine bay lookin like that
    kunifa Guest
    VKnVLCalais Guest
    Talking
    seeing as the car is fk'd why dont u just popout the boot lock with a screw driver and hammer??
    VL to VS
    Mar 2005
    Default oh god
    ahahahahhahahha
    no offence mate, but this is prolly the funniest post i've ever read.
    house keys... lmao
    ...aS thE fOruM JunKie StRikEs aGaiN!...
    Under the seat perhaps???(the keys)..................
  1. Boot Release?
    By Brenno85au in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-12-2006, 08:26 PM
  2. VN Boot Release?
    By kweenkylie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2005, 04:44 PM
  3. boot release
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-11-2005, 09:11 AM
  4. Boot release fix???
    By GH05T in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 03:20 PM
  5. Boot Release not Releasing Boot
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 07:30 PM
