Results 1 to 5 of 5
Thread: Front door squeaking on 88 VL Exec
    VL Executive
    Sep 2009
    Default Front door squeaking on 88 VL Exec
    G'day
    I've done a search of the threads but can't find any links to this; front passenger door squeaking badly, tried WD40 around the hinge, arm no good. Was thinking grease maybe, not sure where to grease up. Any ideas appreciated.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    use a good lube, such as INOX.. or more wd40 move the door back and forth and spray it be generous and get in in there.. try all moving parts... spray it in small gaps on the hinges not on the outside of it.
    not rocket science
    VL Executive
    Sep 2009
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    If it keeps squeaking, try using a lube that says it has good penetration, but yeah, my first thought without even reading this thread was Innox or WD-40 but since you tried that, look for a deep penetration one, or as a last resort, use some grease if you want to get messy. Shouldn't keep going with WD-40/Innox though as my ute's doors used to squeak all the time [It's an 83 Courier, been sitting in a paddock for 10 years before I bought it] and I used a shit load of good penetrating spray and it sorted it after I open and closed the doors about 50 times.
    Oh yeah, I keep saying penetration cos I have sex on the mind. Sorry.
    Just don't mistake it for this:
    |8|7|R|B|3|0|V|L|
    VZ Wagon
    Jun 2011
    Brisbane North
    Quote Originally Posted by stander View Post
    G'day
    If you want to do it properly, there is a flat plate about 12mm wide x 3mm thick which goes through a rubber grummet into the door. It actually stops the door flying open.
    Remove the grummet and use an oil can to oil the plate all the way into the door making sure you get oil on the top and bottom of the plate and plenty of it and keep working the door open and close until the noise stops.
    Once you have done one door, you will probably do the rest.
    You will find it will make the door sooooo much easier to open and close.
    You can use grease instead of oil if you want.
  1. Squeaking noise at front of car
    By nousernameyet in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-05-2011, 06:12 PM
  2. front window squeaking
    By LowVtWagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2009, 10:43 PM
  3. Pedders front left shocker / squeaking noise...?
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2008, 10:46 PM
  4. Door seals squeaking
    By klaw81 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-01-2007, 09:50 PM
  5. Vr exec front door speakers
    By MJR_VR in forum Car Audio
    Last Post: 26-05-2006, 10:43 PM
