Results 1 to 20 of 20
Thread: The VL is dead
    VL executive
    Aug 2004
    Thumbs down The VL is dead
    Finally i feel the sting of not having a car.... for the first time in the ten years that we've had the car it has died. in my books thats an excellent innings... it seems to be just an electrical failure however... heres what happened: driving along the freeway, all of a sudden no warning at all the engine just stops. no struggling or choking it just stops, but i still have all the electrics ie power steering and brakes, so i pull over and try to start it again... turns over, but there's no spark. there's power at the ignition relay, but no power at the dizzy, check the connections and they seem to be fine, but still no start.... after about 10 mins of sitting there trying to imagine what it could be, just for the heck of it i try to start it one more time and it works like it was never broken. go figure... so i drive it home and go to bed for the night... this morning, get up to go to work, same problem... sparks gone again and this time it's not comming back... called racv he couldn't fix it but he organised a tow to the local(ish) auto electrician. btw both the racv guy and the towie were both top blokes can't speak of them highly enough...
    anyone wanna take a guess at what's wrong?
    sorry for the long post.... it just hurts so much not having a car, its never happened before.
    josh
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    it'd have to be a faulty lead wouldn't it? you sure theres no spark at the dizzy?
    VL executive
    Aug 2004
    Quote Originally Posted by bangers
    no nothing... the leads have been onthere for a while but the racv guy traced the cabling as far under the engine as he could (which was a long way before the dizzy ) and there was no charge... it would seem its just abroken wire between the dizzy & the relay... will find out on monday though
    vl berlina wagon 6cyl
    Jul 2005
    I dont know the answer but older holdens were knowt to break copper wires that were vibrated from the engine due to the copper being brittle and eventually breaking due to metal fatigue
    VL executive
    Aug 2004
    Quote Originally Posted by harry3
    entirely likely...
    I have a 'couple'
    Jan 2005
    Bris
    MarzVP's Avatar
    MarzVP is offline I now own a TARAGO!!!
    1992 Tarago
    Aug 2005
    Port Bouvard, WA
    Have similar thing happen with my VP my mate (mechanic) reckons it might be the ignition plate my cover on the wires to the plate is non existant.
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    anfsvl's Avatar
    anfsvl is offline VPDRIVER
    1993 Holden Commodore VP SII EXEC
    Oct 2005
    Hoppers
    ey i onli got my hands on a vl like 4 months ago i got told the Crank Angle Sensor was busted turns out the mechanic told me if it turns ova n sparks tht aint it so my guess is tht is it....or if its not i had tht problem locted down on the distrubter cap the main lead pull it of n wit fine sand paper file the inside of the main hole of the cap n plug her bak in if tht aint it i dunno
    wilkovl Guest
    93 vp ss 5spd
    Oct 2005
    crank sensors are touchy on one of my vls i washed the engine and couldnt
    get the thing started again spent half the day on it then put whole dizzy which was dry in the hot water cupboard over night after a brief stint in the
    oven next morning car was great this lasted about a year
    dont get caught putting engine parts in the oven
    VL executive
    Aug 2004
    can't remember exactly what he said but its something to do with the distributor and the wiring around it... cost me 350 bucks.. prob getting ripped off but i need the car...
    Quote Originally Posted by vp ss 5 cogs
    huh?
    anfsvl's Avatar
    Oct 2005
    Hoppers
    bro i told ya use sum sand paper rool it up n sand the inside of the distrubuter cap onli the center plugh hole if tht dont work get a new lead from the start to the distrbuter...i got a spare if u want it
  15. #15
    albino1986 Guest
    personally i would think your crank angle sensor plug, if the plug itself is not going to well all it takes is a little bump and the car will just stop my car was missing hard at certain revs in each gear, replaced the CAS plug works fine now
    40 bucks for the plug n 20 for labour
    if its your whole CAS pm darkstorm at www.calaisturbo.com.au
    he has full CAS kits for like 160 delivered
  16. #16
    VL executive
    Aug 2004
    it ended up beign the distributor bearing, distributor, and the cas, and 350 bucks... dunno if that was a bit steep but i needed my car...
  17. #17
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
  18. #18
    2003 VY Acclaim
    Sep 2005
    a few months ago now, i had the same sort of problem. driving down a busy road in sydney, car jus stops. wont start again. nrma guy comes round starts prodding at different things with a lil electrical device (my knowledge of cars is limited) and then got it started. went to the auto electrician found out i needed a new crank angle sensor and the plug that goes with it. cost me around $300 as well, so either u didnt get ripped off, or we both did. that problem is fine now, its the other problems that are annoying me now.
  19. #19
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah vlv8vic's probably right, it might be the coil pack but yeah it could be something wrong with the ignition too
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  20. #20
    VL executive
    Aug 2004
    Default results
    hey guys have noticed after the car was fixed, it seems to be getting about 100k's less to a tank... the car runs on gas, and usually gets about 350 to 400ks but now about 250... would this be a result of the work done or just a coincidence and something else is stuffed...
  1. 1 Dead VT
    By VT Berlina 07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2007, 06:47 PM
  2. my bat is always dead
    By hulkstar in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2007, 07:51 PM
  3. Dead VN ECU
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2007, 06:37 AM
  4. From the dead!
    By jetspin_vn in forum The Pub
    Last Post: 07-04-2006, 05:03 PM
  5. One Dead Car - HELP!!!
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2005, 03:09 AM
