Results 1 to 5 of 5
Thread: VL 5spd RB30 sputters and dies occasionally when decelerating
    The V-HELL is offline For the love of VL's
    VL Berlina
    Feb 2011
    Alstonville
    Default VL 5spd RB30 sputters and dies occasionally when decelerating
    hi guys,
    this happened to me for the first time today.
    i was driving along and i started to notice the car was shuddering unusually when i would take my foot off the accelerator. i thought this was abit weird so i tried just tapping the accelerator on and off seeing what it would do. this produced the same result for a few times but wouldnt be what i call regular ( like maybe every 3rd tap of the accelerator would do it).
    eventually the car died and wouldnt start back up again. the engine would crank but it sounded like there was no spark. i checked all the fuses and they were sweet, i checked the coil and the dizzy aswell and they were all sweet too.
    what makes it further interesting is that earlier in the day the right indicator connection started playing up and made the blinker go at double speed compared to the left indicator.....and the rear left speaker would cut in and out sometimes.
    so im not sure if it has to do with maybe a earthing problem or the crank angle sensor is on the way out.
    any advice or insight would be greatly appreciated
    thanks guys.
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    the indicator going at double speed means one of the globes has burnt out or you have a faulty earth on one
    unsure about the shudder - maybe connected to the CAS
    does the car have fuel- sorry had to ask - see if the pump is priming
    does the car have spark when you kick it in the guts
    VL Berlina
    Feb 2011
    Alstonville
    yer its got like half a tank of fuel.
    i'll have a good look at the fuel pump tomorrow to see if it does prime.
    with the indicator the one that was going double speed fixed itself after a bumpy stretch of road so it must be not earthing somewhere.
    when i kick it in the guts when trying to start it it still does nothing, no spark. but i did get it doing like 5 mins after it stalled and it didnt seem to idle very well so i had to constantly have my foot on the accelerator to keep the revs up.
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    sounds like your Crank Angle sensor they are a common fault in vl's
    do a search you should find what your looking for
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    should not "pump throttle" while starting EFI cars man. if u get a backfire it can pop out the AFM hot wire in the VL.
    but no spark is either CAS, power transistor, coil, or ECU..
    give the CAS main plug a hit with some contact cleaner, or wd40/inox etc
  1. Ecotec sputters and shakes when started
    By 97VSV6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2011, 06:42 AM
  2. help!! converting vn to rb30 5spd
    By badger__rox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2010, 08:33 PM
  3. rb30 5spd gear box
    By gen3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-01-2010, 05:16 PM
  4. [NSW] CHEAP VL 5spd (MAYBE auto) wanted for rb30 conversion
    By shmickmik in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2009, 01:40 PM
  5. Dies occasionally (kinda long)
    By 89 vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-01-2008, 04:01 PM
Tags for this Thread
