Results 1 to 7 of 7
Thread: Replacing a Fuel Rail on VL rb30 N/A
    VL berlina - Daily / VS Berlina - Project car :)
    Aug 2010
    Craimore, SA
    Default Replacing a Fuel Rail on VL rb30 N/A
    Hey guys, my vl berlina has a fuel issue and im to belive it's injectors 5 and 6...so im goin to replace the whole lot with a new rail
    My plan is to remove the top half of the inlet manifold, will i need any gaskets or goop when i put it back on????
    Chears
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Yes u will. u will need the gasket for the Intake runners - Inlet plenum and is advised to use some sort of sealant. i use some red sealent which is like a jelly, sorry dont know name of it
    Check the 6 small black seals for the injectors as well. in the inlet as u slowly lift the rail+inj together
    while ur at it flush out the intake plenum with some fuel and clean the throttle body.. get it schmick :P
    dont forget all the vacuum hoses to be put back in the right places and make sure u bleed the air out of your cooling system once the plenum is back on as coolant flows through the throttlebody
    Aug 2010
    Craimore, SA
    Chears man, yea thats what i thought i got some of that red stuff in the shed..its bloody brillant
    Aug 2010
    Craimore, SA
    nope still runs like shit
    just did all the injectors and gave it a throttle body clean...and when i put it in anygear but park or nutral it dies out
    WTF!!!!
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Aug 2010
    Craimore, SA
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    sounds like a trans problem, have you checked your trans fluid?.............. correctly? e.g. at operating temp on a level surface.
    what was the original problem that led you to a fuel issue?
    Nobody wants to play with me
  1. [VIC] FS: 6x750cc injectors and rail to suit RB30
    By VN_Luke in forum Parts And Other Items For Sale
    Last Post: 19-05-2010, 11:58 AM
  2. Tuning questions!! Adjustable Cam Gear, Aftermarket Cam, Custom Fuel Rail, All 4 RB30
    By Kermit (The Frog) in forum Straight 6 Development And Modification
    Last Post: 10-07-2009, 01:46 AM
  3. replacing fuse rail
    By chell in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-10-2006, 06:22 PM
  4. fuel rail
    By brett 46 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2006, 09:38 PM
  5. Steel Fuel Line Into Fuel Rail Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 09:50 PM
