Results 1 to 12 of 12
Thread: Fuel Tank Breather Hose
    Vk 5LTR
    Oct 2007
    Melbune
    Default Fuel Tank Breather Hose
    hey guys im in the process of replacing my current vl tank for a long range tank out of a vr but i need to know where i can pick up a new breather line.its the larger one that go's from the tank and through the chassis rail and connects to the filler.i tried to reuse the vl one but it was a different size and was cracked in some spots
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Vk 5LTR
    Oct 2007
    Melbune
    im gonna say ive been to two different places and both couldn't help me.and i dont know if this is standard but the original hose that came out of it is plastic nylon tubing
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Vk 5LTR
    Oct 2007
    Melbune
    i just spoke to a mate and you said i might beable to get the right hose from holden and meant to be very cheap to
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Quote Originally Posted by detox_nath83 View Post
    use a rubber hose of the same diameter
    its a breather man, don't matter what its made of as long as the tank can breathe.
    A RUBBER HOSE what like 5/8 heater hose ??? wrong advice there . try your local LPG shop and buy a length of hydrocarbon proof hose / vapour line . heater hose is not suitable for petrol use or even vent use . dont mix up your hose's rubber aint rubber .
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    strgas's Avatar
    Oct 2009
    fuel hose
    "Its a Breather" only vapour.......
    ur words in "heater hose" i never stated that.
    yes i used heater hose as an example of a " RUBBER HOSE "
    being a breather hose does matter as the fuel vapour can still effect the hose if its not of the right grade or construction for the job , years of converting cars to LPG and repairing cars seen incorrect use of hose's so many times which leads to failure of engines transmission diffs power steering pumps and racks etc etc .
    Vk 5LTR
    Oct 2007
    Melbune
    strgas's Avatar
    Oct 2009
    plastic is factory cheap to produce goes hard after years thou and becomes rather brittle easy to break recommend replacing with hydrocarbon proof hose , if your plastic hose is in ok condition you can cut it in the middle and extend it with a piece of metal pipe
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    thats fair enough man,
    but anything that will not deteriorate will be sufficient thus using fuel hose.
    i know that all hoses are different as in oil safe/fuel safe/pressure rating, etc etc
    not using trans hose for a fuel line etc.
    Vk 5LTR
    Oct 2007
    Melbune
    rang holden this morning and there stil sell the breather hose cost a whopping $3.85
  1. Fuel breather hose?
    By calais24/7 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-06-2010, 09:29 AM
  2. VN Fuel Tank - Breather hose?!
    By xXBoofXx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 08:16 PM
  3. Where do I run a breather hose from my fuel tank to.
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 08:30 PM
  4. Help!!! Putting fuel tank back in with new breather hoses..
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 11:25 AM
  5. Fuel tank breather plumbing
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 04:20 PM
