Results 1 to 3 of 3
Thread: Thermo Fans for Vl Turbo
    Vk 5LTR
    Oct 2007
    Melbune
    Default Thermo Fans for Vl Turbo
    hey guys can someone explain if there is any benefits from using a pair of thermo fans from the normal clutch fan
    and what thermos fans fit up with minimal mods; au el etc
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    mate go the single 16" one with a Davies Craig thermo switch to control it..
    Lazza78 has this on his VLCT. More engine response as its not dragging a fan (His clutch was stuffed) and keeps it cool as
    there is some mods to do to the fan shroud but not as much as installing twin au thermos etc etc
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    as nath said... i fitted a 16in fan to my calais about 6 weeks ago, my old fan was locked solid and could not even turn it by hand in the end...
    depends on ya cooler piping but if u have a standard inlet and ur cooler piping runs in front of the radiator twin fans is a no-go...
    with the single 16in and only used the top half of the fan shroud and i also used the davies craig thermo control switch with it, takes a bit of muckin about to get the fan to cut in when u want it too but all up, took me 2 hrs from start to finish(fitting fan, wiring controller and setting the controller up)
    hope this helps mate, any Q's send me a pm..
    Larry
  1. Thermo Fans
    By psychotic46 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-07-2011, 05:14 AM
  2. [VIC] AU Thermo Fans
    By Sabbath' in forum Parts And Other Items For Sale
    Last Post: 15-08-2010, 10:16 AM
  3. thermo fans
    By v8commy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2009, 02:04 PM
  4. Thermo fans?
    By vkwalks39 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2009, 07:50 PM
  5. WTB EL to AU Thermo Fans
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2008, 05:40 PM
