Results 1 to 10 of 10
Thread: brake pad warning noise?
    vl berlina wagon 6cyl
    Jul 2005
    Default brake pad warning noise?
    VL brakepads have a wire clip on the top that doesnt connect with anything, looks like its there to rub on the rotor when the pads are worn down to make a noise, warning that the pads need replacing
    cant find any mention of this in the handbook or a workshop manual, if so how loud is the noise?
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I'm trying to think of the clip that your talking about? Could you get a picture.
    I'm fairly sure its not for that reason though.
    VKnVLCalais Guest
    that is a wear indicator. the noise is like a RINGING, whining noise. i dont think they had them on the original brake pads so theres prolly no mention of them in the manual. if this is the case they must have started putting them on pads in the 90's, im guessing anyways.
    all mazda pads have this wear indicator (this is where i work )
    stock_vl is offline wh internationals?
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    no idea... brought new break pads other day and dont know what your talking about!
    theres like a sort of spring up the topthat just sits there i dunno if its ment to squeal or anything.. i thought it was there to put pressure on something... oh well..
    I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    VT
    Apr 2005
    QLD
    i am pretty sure that the spring is there to stop the pads rattling when the brakes are off. had a problem with my vg ute, slight rattling noise was coming from drivers back brakes, found out the spring had lost tension and was rattling in the caliper.
    Bax
    Nothing
    Jan 2004
    QLD
    I'm still trying to get an idea of what these springs look like. Are they on the actual brake pad? I'll have to have a look as I can't remember it at all.. Vaguely remember seeing a metal clip on the pads themselves.. But yeah, I'm still standing by that they're not there to make a squeak.
    VT
    Apr 2005
    QLD
    there should be a little lug on the outside centre of the pad. attached to this should be a spring usually made out of wound wire which extends out to each end of the pad. this presses against the inside of the caliper to stop the pad flopping about when the brakes are off. I am not saying there is no such thing as squealer pads, because toyota use them alot, it's just in this instance, they sound like the anti-rattle springs.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    yeah my old pads had these. and a friends VK had them as well. just a little wire that you would hear quite easily when the pads were on their last legs.
    the new ones i used didnt have them.
    VKnVLCalais Guest
    when the pads wear down the metal rubs against the rotor to let u know its time for replacement.
  1. Noise From the Brake/Tyre
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2006, 09:48 PM
  2. VR Hand brake warning light
    By dean18 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 12:42 AM
  3. Brake Warning light comes on
    By Sambo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-06-2005, 06:58 PM
  4. Hand Brake warning light
    By tweezy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2005, 08:20 PM
  5. Tail/brake Lights Warning Lamp
    By Frederick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2004, 07:19 PM
