Results 1 to 8 of 8
Like Tree4Likes
  • 3 Post By Reaper
  • 1 Post By 87RB30VL
Thread: how to stop this damn ticking noise. Help me please!
    vl berlina
    Sep 2011
    adelaide
    Default how to stop this damn ticking noise. Help me please!
    hi guys my vl is ticking away pretty bad from the top of my motor.When its cold it doesnt make a noise till its warm then it gets pretty loud. once its hot over a period it starts off not making a noise then gets louder and louder then stops. Then starts over again. Got told to put thicker oil in it so did the whole oil change and it made it louder. What ya think i should do
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    pull the rocker cover off and fire it up! let it warm up dont rev it as youl cop a face full of oil. try and pin point the sound. could be a dodgy lifter, check all rockers and rods for looseness and play. if its an rb30 just take it to the scrappy lol
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    common rb30 problem, noisy lifters, fresh oil and filter and a bottle of lifterfree usually does the trick, however it won't fix it immediately it takes time to work.
    other options are replace lifters, remove lifters and have them properly cleaned.
    other, check oil pressure to make sure the oil pump is not failing.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    regular oil changes will rectify this problem as it will clean the motor.
    as stated noisy lifters is common. bet if u pull the rocker-cover it will b gummy as buggery
    advised not to use engine flush either
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Changing oil and covering up the noise wont reverse the damage. Remove the lifters and check the hardened surfaces for pitting and chipping. Remember that damage on one surface will affect the other.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    VL Calais V8
    Sep 2011
    11/39 Bennet St, Dandenong
    Hate to say it, but it's your lifters most likely. My missus was driving my 5.0L VL Calais around with music blaring for months, and then one day decided to tell me it was ticking a "little". When I filled up the oil, it took a whole 5 litres, and when I took it home to check it out, realised she had done the lifters! Silly girl! LOL
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Best thing for a VL:
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Best thing for a VP:
    Lol, totally agree with you right there.
    |8|7|R|B|3|0|V|L|
  1. Ticking noise
    By Dee jay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2011, 12:03 PM
  2. VK Ticking Noise.
    By Pie-VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2011, 12:38 AM
  3. ticking noise in L67....
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2009, 05:45 PM
  4. Ticking Noise
    By chitchat2000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 10:35 PM
  5. Ticking noise!
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 05:30 PM
