Results 1 to 4 of 4
Thread: has anyone had this problem think its todo with the afm
    1987 vl sl
    Apr 2011
    adelaide
    Default has anyone had this problem think its todo with the afm
    so my car was running really rough. not the 1st time but this stopped after running it on premium. then the problem came back about 3 months down the track. so i unplugged the afm while the engine was running it turned straight off when i turned the car back on everything seemed to be 100% again. any info on this is this a sign that my afm is about to shit itself or just a loose connection??
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    if ur car stalls when afm is unplugged the afm is working properly.
    if your car idles with the afm unplugged its failing..
    give it a hit with some inox/rp7/wd40(the plug pins and socket)
    check ur timing man should b 15degrees(factory) there are so many things that can make the rb30 run rough so start fault finding starting with the cheapest first
    1987 vl sl
    Apr 2011
    adelaide
    but its working fine now so could it still be timming or is that out of the question? and what does the adjustment screw thing do?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    dont touch the adjustment screw.. that the fuel/air mixture.. leave it factory(Look in my sig on a how to test afm and set to factory specs) if somebody has played with it b4..
    if its an intermittent problem it could b something else like the CAS as well
    wont hurt to check ur timing anyways. but its not a timing problem u have
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. What more todo?
    By edals in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2010, 03:54 PM
  4. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  5. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
