Results 1 to 22 of 22
Like Tree2Likes
  • 2 Post By iaydemir
Thread: RB30 milky oil
    vs commodore
    Aug 2011
    Default RB30 milky oil
    I picked up a VL 5 speed today and it has milky oil in it, it's milky at the cap and the dip stick and its like a brownish color. My mate said it has a cracked head or head gasket and to try Chemiweld. Anyone have any ideas or experience with Chemiweld? Also is there any way to tell the difference between a cracked head and head gasket without pulling the engine apart?
    drewVHSS's Avatar
    drewVHSS is online now Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    not sure how to tell the difference but the most common issue with rb30's was to crack the head if the cooling system wasn't bled properly.
    So i seriously doubt it was the gasket in the case of 99% of VL's
    In day's gone by, i used to for a job, weld the heads up.
    Try ol mate Carl at seven hills for a head job.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Does the car overheat?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    iaydemir's Avatar
    iaydemir is offline Donating Member
    VY V6 Berlina
    May 2009
    drewVHSS's Avatar
    Apr 2010
    I was serious... but after you posted, i realise it came out wrong..... oops. Carl at head works seven hills, old mate of mine and my old business partner. Does good work.
    Now if you were going to turbo that vl... then that head job would go hand in hand with a blow job! lol
    vs commodore
    Aug 2011
    Quote Originally Posted by sweefu View Post
    not too sure i only just picked it up and it has no rego to take it for a drive. should i just start it and let it sit?
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Sounds like a cracked head. make sure your fluids are up, start her ,and let her idle until warm temperature [On my VL it's about 1/4 on the stock temp gauge, or 70 - 80 degrees celcius on my aftermarket gauge. anything more & it's either really really hot outside or you have a problemo.
    |8|7|R|B|3|0|V|L|
    vs commodore
    Aug 2011
    i let it run for 10 minutes and it got to about half way before i turned it off. I'm going to start taking the head off anyway.
    vy2 clubsport
    Feb 2008
    adelaide
    Half is about where the temp should be sitting.
    Is it white?you said brown?
    Post a pic up of oil.
    Either way if it's a gasket or head do it rite the first time replace the gasket and reco the head at same time.
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i hope you did check it before you brought it?
    any way i have a good rb30 engine for sale haha
    My VL Walkinshaw replica project
    vs commodore
    Aug 2011
    It's like a coffee color at the dipshit but more greyish under the oil cap and yeah i checked it before i bought it i picked it up as a project. I got half way through pulling it out tonight will finish the rest in the morning. is there anyway i can tell myself if its the head or the gasket once i have the head off?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    don't b an idiot and try drive it.
    its got a cracked head or gasket blown. (hence milky oil/water)
    give it back and get your money back.. or pull the head and get it checked.
    if its good get it machined and get another gasket and torque up the bolts in correct sequence and torque settings.
    VX SS
    Jul 2005
    East of Melbourne
    Like the others have said fix it properly, but a bit of personal info on Chemiweld, I had a VL Berlina company car back in the 80's, well actually the company had quite a few brand new VL's and maybe half suffered from cracked heads at one stage, the Berlina I had was soon due for replacement and it started to overheat and the oil turned milky, as it was going to be traded the mechanic said try the Chemiweld you will be surprised, well he popped in the Chemiweld and changed the oil and coolant and to my amazement it was like new, we traded it on a VR at the time and had to wait a couple of months for delivery and it never missed a beat during that time, and the oil was as clean as the day it was put in. The Holden dealer that did the trade commented on how well the car ran. But had it been my car I would have fixed it properly. But the Chemiweld does work or it did in my case.
    vs commodore
    Aug 2011
    I picked up another engine for it today so dontt have to worry about the engine oil, but i just pulled the 5 speed box out of it and the damn oil in that is milky too. wtf is going on here.
  15. #15
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Milky gearbox oil has something to do with like, water getting in somewhere or something I heard, not too sure on the details about gearboxes, though.
    |8|7|R|B|3|0|V|L|
  16. #16
    VL Berlina
    Aug 2005
    Perhaps the VL has been completely submerged in water. Did you buy it from a flood prone area ?
    That may explain how water has got into both the engine and gearbox.
  17. #17
    vs commodore
    Aug 2011
    Quote Originally Posted by grazm View Post
    nah no flooding around here, unless they drove it into a dam im not sure how it would get submerged.
  18. #18
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Could be just old thrashed out oil with metal particles. That will look like a silvery/milky oil
  19. #19
    vs commodore
    Aug 2011
    Quote Originally Posted by VL_5SPEED View Post
    That is exactly what it looks like, is there anyway i can flush the box out of the car or should i just do it when i put it back in?
  20. #20
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
  21. #21
    Aug 2007
    Newcasstle
    not sure. I personally wouldnt worry about it i would just fill it back up with fresh oil lol.
  22. #22
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    pump it out by pulling a hose at the rad(trans cooling lines) and run your car in idle untill its pumped out.
    Have a mate watch it and as SOON as it stops, turn off your car as u can damage the box/converter.
    i done it this way plenty of times. then undo all trans sump bolts and drop the pan.
    New cork seal and seal her back up. new trans oil and boompa. done
  1. milky slime in top of motor
    By peeingeye in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2009, 06:01 PM
  2. vs commodore got milky oil
    By snowy213 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 07:19 PM
  3. Please help Milky oil issue
    By V85000i in forum General
    Last Post: 14-12-2007, 05:54 PM
  4. Milky Oil
    By fjdave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2007, 02:09 PM
