Results 1 to 15 of 15
Thread: Diognosis please!
    VZ Calais
    Aug 2005
    Mackay Qld
    Exclamation Diognosis please!
    RB 30 turbo. On hard acceleration,hard cornering, the car coughs, dies for a moment, the shoots off like a rocketship! Could it be fuel starvation? Can fuel injected cars suffer from this?
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    VT SS S2 A4
    Aug 2005
    VZ Calais
    Aug 2005
    Mackay Qld
    Starts fine. One injector is weeping,dont think that will do it. Fuel load makes no difference either.
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    start by getting that weeping injector fixed. it needs to be fixed anyway, so if it fixes your problem double the fun!
    VZ Calais
    Aug 2005
    Mackay Qld
    This is the 3rd injector which has failed, The last 2 didnt make any diffwerence! Only made it easier to start.$180 each,
    VR Berlina V6
    Sep 2005
    orange
    Check out ebay, theres a guy that sells the in a set (reco) for what your paying for 1, he also does an exchange so cheaper still.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    If you gave me 100 Dollars I'd give you 6 of my old n/a injectors.
    They're all second hand though and could use a clean.
    Ms Stato's Avatar
    Ms Stato is offline And?!?!
    VQ Stato 5.0L
    Oct 2005
    Near Bris
    Not that i know much about this BUT....
    My other half had a cracked injector in his car... under high boost it would lean out and then pick again...
    maybe that weeping injector is the prob... or maybe i should shut my gob LOL
    V8 VQ Statesman
    It's MINE not his
    VZ Calais
    Aug 2005
    Mackay Qld
    The turbo injectors are different from standard injectors!!! Will check ebay. Cheers
    Bax
    Nothing
    Jan 2004
    QLD
    Ahh sorry, didn't realise it was turbo.
    Most sets go for around 250+ second hand.
    VZ Calais
    Aug 2005
    Mackay Qld
    every time i've pulled the rail, i've had them cleaned. And new hoses fitted with new clamps. Under $100 each time. Thats for a set.
    Bax
    Nothing
    Jan 2004
    QLD
    100 dollars a set to clean? Thats pretty good value. I paid 200 and that wasn't including hoses.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    a weeping injector should only create smoke out the exhaust. with fuel flow the relay for the fuel pumps, remembering there are two pumps, make them either flow at full flow or not at all. it doesn't matter how hard you accelerate the flow stays the same. the prob could be from a stuffed filter, the primary pump could have a full strainer, or one of the pumps could have an intermittent fault. the fuel return line could be blocked too. start at the cheapest fix and work your way up. depending on mods you may need a fuel regraph.
  15. #15
    VZ Calais
    Aug 2005
    Mackay Qld
    Found the problem, i think. I was doing the weekly fluid check,& now i have 2 leaking injectors! Filter is probably stuffed too. Been meaning to change it! Looks like the fuel rail is comming out again! Anyone got used turbo injectors? Reco price was $15 per injector including new hoses & clamps. But if the body leaks, they are throw aways. New price is $160-180 each.
