Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By Lucaas
  • 1 Post By jatsvl
Thread: Looking for vl wagon manual conversion parts
    vl wagon
    Oct 2011
    marybrough vic
    Unhappy Looking for vl wagon manual conversion parts
    hey guys im chasing a vl conversion ive got the gearbox, need everything else . cheers
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Also on this topic, I'm hunting the same parts for my sedan for an auto to manual conv. What parts do you need to do one?
    Sorry for asking in your thread VL2env
    |8|7|R|B|3|0|V|L|
    VL Executive
    Sep 2011
    Sydney, NSW
    87RB30VL , basically to do the conversion you need Gearbox including clutch and flywheel, pedal box, tailshaft, and the interior centre bit then everything needs to be aligned it can be kind of a hassel if your doing it yourself in your drive way, i did mine a few months ago but at work, up on the hoist. Pretty time consuming.
    VL2env, Hey mate there is quite a few of them going on Ebay, just have a search and normally include a re-conditioned Gearbox, its always good to have a spare box, hahaha.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    there is a really good "how to" on here somewhere.
    also OP I am sure you are aware wagon and sedan are the exact same parts as far as running gear. you specified wagon in the thread title.
    Nobody wants to play with me
    vs commodore
    Aug 2011
    Quote Originally Posted by jatsvl View Post
    i think the wagon has a different size tailshaft, maybe they are the same from auto to manual though like the sedans. for an auto to manual conversion you will need - manual flywheel, manual starter motor, clutch and pressure plate, clutch reservoir, , inspection plate, manual pedal box, the plate that goes in your car around the gear shifter, i think you also need the brackets that sit at the bottom of of engine that bolts to the bell housing. that's about all i remember. I also remember when i changed mine from auto to manual the spigot bush wouldn't fit and i had to get it machined.
    Best idea imo is to find a car that is already a 5 speed and use it for your conversion that way you know you should have all the pieces
    vy2 clubsport
    Feb 2008
    adelaide
    You don't need a "MAGIC" manual starter motor the auto one does the same job!
    Don't forget to bridge the neutral safety switch either.
    It's a piss easy conversion I've done it a few times. Just a tip for the pedals I found it quicker to remove the steering column to make it easier to get pedals in but that's just the way I done it.
    Good luck. Oh yeah wagon has a difrenrt tailshaft to sedan to
    vs commodore
    Aug 2011
    Quote Originally Posted by bow down View Post
    My bad, you don't need to change starters for VLs like you do with a VS.
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by asht12341234 View Post
    wrong! tailshaft wagon and sedan are the same (upto VN), auto and manual are different.
    starter motor is the same, spigot bearing needs to be replaced.
    edit; my wagon has a sedan tailshaft in it.
    vs commodore
    Aug 2011
    I never changed my tailshaft when i converted my old VL and i had to get the spigot bush machined because it was too big. I'm just telling the guys what i had to do.
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    no offense implied no offence taken mate, supplied info should be accurate.
    I am pretty sure if you have done this conversion on a VL previously you would have had to change the tailshaft or at least the yoke,
    auto and manual tailshaft are different. I am happy to be proven WRONG!
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Can you only swap a VL gearbox into a VL or is there other boxes you can swap in cos' from my searches, manual boxes are hard to get
    |8|7|R|B|3|0|V|L|
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by detox_nath83 View Post
    Justo arnt they the same but one yoke is huge compared to the other....?
    spelling corrected!
    to my understanding the teeth inside the YOKE and gearbox are different. auto and manual.
    87RB30VL you can use a variety of boxes BUT modification is needed.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  15. #15
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    spelling corrected???
    Justo..... (slang for u man ......Justin) soz i add "O" to most ppls names when i can lols...
    well I am used to Juso (pronounced JUZO), but call me anything, just don't call me to late for dinner, money or SEX with my missus. they are ALL to far and few inbetween.
  16. #16
    vs commodore
    Aug 2011
    I did this conversion nearly 10 years ago when i was on my L's, i bought a 5 speed (whole car) for parts and it had no tailshaft. I had no problems at all with the tailshaft fitting straight in. Doing a bit of a google search it looks like some people said their's bolted up and some didn't. Have you ever actually tried to use an auto tailshaft? im curious now, maybe there is more then 1 type or something.
  17. #17
    VL berlina
    Dec 2009
    if you need i have a flywheel and both cables needed, if there are two otherwise i have two of each... either way $50 there yours
  1. [VIC] T5 Manual G/box out of 88 VN Wagon. Everything for full Auto-Manual Conversion
    By Shaz77 in forum Parts And Other Items For Sale
    Last Post: 11-06-2011, 04:05 PM
  2. [WA] FS: VL Parts, V6 Conversion manual kit, VN-R Parts
    By Jordo2 in forum Parts And Other Items For Sale
    Last Post: 10-02-2010, 10:44 PM
  3. VS Manual Parts Conversion on VR
    By VR comme in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2009, 07:59 PM
  4. [NSW] WTB: Getrag conversion parts for V6 VX wagon
    By DavidPartay in forum Swap / Wanted to Buy / Trade
    Last Post: 12-08-2009, 09:29 AM
  5. [NSW] WTB: V6 VX Wagon manual conversion parts
    By DavidPartay in forum Parts And Other Items For Sale
    Last Post: 29-07-2009, 08:56 AM
