Results 1 to 9 of 9
Thread: Fuel pump constantly priming on startup
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Default Fuel pump constantly priming on startup
    Ok so the other day, after finally getting my VL back on the road after about 6 days of sitting in my driveway, I noticed that my fuel pump primed upon turning the ignition on, but just kept making the "whiiirrrrrrrr" noise. I turned the ignition off, and back on, and it primed and stopped like normal. That afternoon, I took her in to get the cylinders in the drums replaced, and when I turned her on, the fuel pump was constantly going "whiiiirrrrCLICKwhiiirrrrCLICKwhiiiiiiirrrrCLI CK" but the car starts and runs fine.
    I had a new fuel pump put in not too long ago, probably a few months, so it's not like it would be my pump?
    Any ideas? I don't like the fact that the pump keeps running when my ignition is on, where is that fuel pumping to? I have no leaks as far as I can see from looking under the car for spots etc and my fuel has stayed up since I filled her up the other day.
    |8|7|R|B|3|0|V|L|
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Check that the regulator on the fuel rail isn't buggered...Sounds like its just feeding straight back to the tank
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    I'll have to have a squiz tomorrow, would it be doing any major damage if the regulator is stuffed?
    |8|7|R|B|3|0|V|L|
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    No not really... Just relace it.. I dont think they cost much... Mind you, I have never bought ove for a VL.. Id think under $20?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    yeah man sounds like its not pressuring hence constant priming,
    i would think its the reg as well(leaking past the diaphragm and not holding pressure.)
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Are the VL regulators located in the tank? Or are they in the engine bay? I can't remember seeing one under my hood, though I could have overlooked it. I think my brothers is in his engine bay of his BMW and it stands out like a sore thumb but I haven't seen anything like it in my bay.
    |8|7|R|B|3|0|V|L|
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by detox_nath83 View Post
    Click image for larger version.
ID:	127363in the bay man under the plenum. (Mine is Disconnected)
    Ah, thanks bro, can you remove it without having to remove the plenum at all? As in, just buy a generic one and swap it over in my yard?
    |8|7|R|B|3|0|V|L|
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    its held in with 3 Phillips head bolts man and only can get at them with the top plenum removed...
    before actually knowing if this is the problem try another reg hooked up first. the changeover you will need the plenum gasket(between plenum/runners)
  1. VS commodore CAS or Fuel Pump? Fuel pump new BUT not priming on accessories
    By robert422 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2012, 08:14 AM
  2. Priming 304 oil pump
    By 304runner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2011, 11:06 PM
  3. Priming 304 oil pump
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 03:16 PM
  4. fuel pump not priming
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2006, 09:11 PM
  5. fuel pump priming problem
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 11:57 PM
