Results 1 to 8 of 8
Thread: timing belt marks?
    vs commodore
    Aug 2011
    Default timing belt marks?
    Just wondering if anyone can tell me where my cam and crank should be sitting when i put my timing belt back on. I rushed into it and pulled it off now i have no idea how to put it back on.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    vs commodore
    Aug 2011
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Vl Calais Turbo, Vn Calais 5L
    Feb 2011
    Sydney-west
    let's just call it a save, that you asked first because the mistake has been made way too many times over the years.
    vs commodore
    Aug 2011
    Quote Originally Posted by Vlt_Calais View Post
    Well i wouldn't of tried to put it back on without knowing the correct way. thanks again detox_nath my car is running great.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VL Series 200 , 85 VK Berlina, VL Executive Wagon
    Apr 2010
    also make sure your number 1 piston is at (tdc) top dead centre because the cranks gear (bottom gear) will have say 12 teeth on it and the cam gear will have say 24 (twice as many teeth as crank gear) this means that when the crank turns the timing belt which turns the cam gear it will take 2 rotations of the crank to turn the cam a complete 360 degrees . So make sure you get that right. google how to safely check for TDC.one way would be taking out the no. 1 spark plug, disconnect the plug to coil and remove the fuel pump fuse and then crank the engine for only a second or two. in the plug hole tightly stuff in a piece of clean rag with some oil on it so that when you crank it the compression will spit the rag out when the piston hit TDC. then you will know your close and can look at where your dot is on the cam gear. hope that helps.
  1. Timing Belt
    By astroham in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-01-2011, 09:08 PM
  2. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  3. timing belt!!!
    By ImAHoon! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-12-2008, 11:27 AM
  4. 5L timing marks..
    By DenchY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2006, 03:40 PM
  5. V8 Timing Marks
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2004, 06:35 PM
