Results 1 to 10 of 10
Thread: cold air intake..........advice?
    wicko Guest
    Cool cold air intake..........advice?
    i have an vl i have cut a hole in air box got a 3 inch pipe flowing to the bumper a bmc performance filter i have heard if u punch out the mesh in the afm (air flow meter) does it give your more power????
    VT SS S2 A4
    Aug 2005
    SNY.3LT Guest
    i wouldnt advise it, its there for a reason and its not even really that closely wound together.
    I havnt done this but does taking your air filter out give you any increase in power or does the air flow through it quickly enough
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    rb26dett is right, if you did you wouldnt even notice it, and its a pretty stupid idea in the first place
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    how much power does the cold air intake give u? and also does it cool down the head any more then it was? coz i wanted to do the same...
    I wonder what those scales on the top right side of my posts do...
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Stewart1000
    you're right, you probably wouldnt notice it, but why is it a stupid idea? the mesh as we all know is there to seve a function, to ensure the air 'straightens up' in effect, to give a more accurate reading acroos the afm and it also prevents larger objects from reaching the engine should a filter failure occur. but if you look after your car and check the filter regularly and you are porting and polishing the innards of your throttle body and inlet manifold etc, is it such a stupid idea?
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    Somewhere in these threads they were discussing the restriction that the afm mesh has and is higher than some other things. Take for instance a fly screen door, once open lets a hell of a lot more air through, than what it would if it was closed. I do believe they're there for a reason but what reason? I left the front one in basically to protect the air flow meter, but i couldn't see y i should keep the back, so i removed it.
    I wouldn't recommend ever not having a filter panel or pod either. Just make sure you have a high flow one.
    VT SS S2 A4
    Aug 2005
    They are there because they are meant to protect the AFM filiment from large objects, like if somehow a stone got past the filter ( I know, the chances of it happening are almost zero )
    There are things you can do before you go messing around with that.
    rimz81 Guest
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    My hi flow panel filter has wire mesh on it so I took both mine out, It does make a sort of a howling noise when the revs pick up in 2nd ( I like it hehe), and yes the AFM meshs are the most restrictive items on the whole intake system if your fitting a hi flow filter and leave them in you will not gain any more air flow than a standard filter can deliver.
    ========My Statesman 20's Mafless and 3.9's========
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Cold Air Intake VS
    By Wilson_752 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2007, 09:48 PM
  3. Wtb Hdt Cold Air Intake
    By BLOW6 in forum Swap / Wanted to Buy / Trade
    Last Post: 27-02-2007, 04:34 PM
  4. Ram cold air intake
    By Soybean in forum V6 Development And Modification
    Last Post: 12-02-2007, 08:54 PM
  5. VP Cold Air Intake
    By habro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 06:26 PM
