Results 1 to 5 of 5
Thread: VL not starting HELP
    Oct 2007
    Default VL not starting HELP
    i am having troubles starting my vl i have replaced the ecu due to water damage but now it wont start could anyone help with test is could do to find the problem thanks
    any1 help???
    hello i have looked at the codes on the ecu and it hasent got code 11 which is the Cas so would it be the coil or PT if anyone could help with some test i could doi to find what it could be would be helpfulll thanks
    i have relizes that the plug where the cas is is lose like the cas bolts are lose maybe is this ment to be lose ??
    is the cas ment to be lose?
    thanks
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    VS commodore wagon V6
    Aug 2011
    Windsor 2765
    Oct 2007
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    tighten as u said its loose... follow guide on diss assembly of Dizzy
  1. vr not starting
    By jt_vrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2010, 05:04 PM
  2. car not starting at all
    By crazstaat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 05:40 PM
  3. Vn Not Starting.
    By K1ND3R in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 09:18 PM
  4. 5L not starting
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2008, 11:59 AM
  5. no starting sometimes
    By phoenix_blue in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 01:33 PM
