Results 1 to 8 of 8
Thread: My Vl is having starting problems
    Cherrys Guest
    Angry My Vl is having starting problems
    [IMG]red vl 2[/IMG] hi guys
    i am kinder new, but i have a question, I brought this 1988 vl sl a few mounths ago and it is haaving problems starting, it starts fine when it is cold but when it is warm and i go to restart it, it takes an extra effort to do so, i think there is something wrong with my dizzy, dont know, can any one help me out because it is anoying.
    [IMG]
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    i have that problem but the other way round is crap at starting first thing in the morning starts on about the 3rd or 4th attempt thou
    justcommos Guest
    I think i got the solution for you....
    I know that the ford XFs had a very similar problem, turns out it was the solenoid on the starter motor. Now and then it will happen - maybe even when cold, but when hot, it is more prone to happening. It's no guarantee to be the solution in this case, but a possibility.
    You could try this.... next time it's having trouble starting just tap the solenoid (or the whole starter), should free it up a bit.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    do you mean it struggles to turn over or struggles to fire?
    if its the first itll be the starter motor. 3 main possibilities - stuffed brushes, stuffed solenoid or old wiring in the VL which requires a few wires and a new relay.
    If its the second issue id be checking the afm and the coil. dizzy should be ok.
    albino1986 Guest
    have a look at your crank angle sensor plug, my car was doing that and also was misfiring hard at a certain rev in each gear.
    poor start up and misfire was due to dizzy cap n rotor, got them replaced, improved by about 30% then got CAS plug replaced worked perfectly now.
    Cherrys Guest
    hi guys
    thanks for those tips and yeh it struggles to start, it has no problem what so every turning over
    ElDubya's Avatar
    ElDubya is offline Mad As A Meataxe
    1994 VR SS Sedan
    Jun 2005
    According to my trusty EFI Fault Diagnosis book, it lists :
    Engine Hard To Start When Warm :
    Fuel Supply
    Air Regulator
    Limp Home Mode Set
    ECU
    Have you had a look at the ECU and pulled any codes off it? There are a red and green LED on the side of the ECU. The red LED represents ten units and the green LED represents single units. EG : If you get 3 red flashes and 2 green flashes, that indicates Code 32.
    How to extract codes :
    1. Remove the left hand kick panel and carefully turn the mode selector on the ECU fully anti-clockwise.
    2. Turn the ignition on and ensure that both LED's are lit.
    3. If the LED's are not lit, check the continuity of the ECU power amd earth circuits. If the power supply and earth are satisfactory, renew the ECU.
    4. Carefully turn the selector fully clockwise.
    5. Start the engine and allow it to idle. If the engine cannot be started, operate the starter for at least 2 seconds to cancel Code 32 and proceed to step 9.
    6. If the engine will start, Codes 14, 23, 24 and 31 (non air conditioned) should be displayed along aith any other codes currently in memory.
    7. Drive the vehicle at a speed greater than 10 km/h to cancel Code 14.
    8. Stop the engine and turn the ignition switch to the ON position.
    9. Depress and release the throttle pedal to cancel Code 23.
    10. Move the gear selector to any gear and back to neutral to cancel Code 24.
    11. On vehicles with air conditioning, turn the air conditioning switch on and off to cancel Code 31.
    12. If any codes other than 31 (non air conditioned) or 44 (air conditioned) are displayed, check the components affecting the operation of the circuit indicated under that code number.
    CODES :
    11 Crank Angle Sensor Circuit
    12 Air Mass Sensor Circuit
    13 Coolant Temperature Sensor Circuit
    14 Vehicle Speed Sensor Circuit
    21 Ignition Signal
    23 Throttle Position Sensor Circuit
    24 Neutral Switch
    31 System Pass (non air conditioned vehicles) or Air Conditioner Circuit (air conditioned vehicles)
    32 Starter Signal Circuit
    34 Detonation Sensor Circuit (turbo models)
    44 System Pass (air conditioned vehicles)
    Clearing Codes :
    1. With the ignition on, turn the mode selector on the ECU fully clockwise for at least 2 seconds.
    2. Turn the mode selector anti-clockwise for at least 2 seconds.
    3. Turn the igniton off.
    The very existance of flamethrowers proves that sometime, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to do it.
    vl calais rb20e 1987
    Sep 2009
    Unhappy motor starter not crank when start
    hey guys, i have problem my vl rb20e dinamo starter not crank.signal starter ok...please thanks...
  1. Problems starting a VK 3.3 EFI
    By 2_SeeK_U in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-09-2007, 09:13 PM
  2. VR V8 starting problems
    By jasonb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 11:54 AM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. VT SV6 starting problems
    By geebee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2005, 08:43 AM
  5. Starting problems
    By Chris in forum General
    Last Post: 30-06-2004, 09:17 PM
