hi those any1 know y when i put my indicator on my interior light goes on and starts flashing in my vl berlina series 2. any help would greqatly be appreciated
ok im guessing there is a short some were betteen ur indercator n ur interor loom switch cos the indicator is connected to the head lights n the headlights switch on ur dash bored n in my vl to dim ur dash tht switch also turns on ur interior loom lights so im guessing its sumwhere dere
okay thanks is there a easy way to do this
always pays to look in the boot. commodores have a serious issue with boot earths and damp connections to the tail lights. these issues can cause a massive number of interesting problems.
what are the dash lights doing? anything different?
they go a bit dim and also my handbrake light is always on why is that like that
would a faulty flash unit make it do that
nah i think the flash can would be ok. it sounds more like a short somewhere or a dud earth. Seriousely check all the connections in the boot.
Handbrake light might be in the actual switch, pull the boot off the handbrake, disconnect the switch and see what happens, it might need some forceful adjustment or replacing.
okay cool thanks vlv8vic u wouldn't happen to have any wire diagrams would you. would appreciate it very much
nah nothing sorry mate. just have a look for corroded connections, loose earths etc.
okay cheers mate i will have a look also in the boot there is a wire and a button next to the right hand side near the boot hinge wats that for.
That'd be for your boot light, i disconnected mine behind the light itself, got some piggy back spade terminals (so you don't have to cut the insulated spade bits that connect up the light), and connected my neons into them. Looks better than a normal light, only prob is they're green and my sub is red kinda don't go togetherOriginally Posted by slwbt1
