Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By detox_nath83
Thread: rattle from the rear
    vs executive
    Mar 2011
    merimbula
    Default rattle from the rear
    my vl all of a sudden developed and light rattle, sort of a buzz from the rear of the car.
    could this be my fuel pump?
    when i knock the tank it stops it for that split second but starts again straight after.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    could also be worn or broken exhaust hangers causing the rear muffler/resinator to rattle on the side of the fuel tank.
    Nobody wants to play with me
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    My exhaust was rubbing on the rear of my car cos' one of the rubbers that holds it up had snapped. Piece of wire solved that problem. Also, my fuel pump whines like a bitch so don't worry about it, and I just recently got a brand spanker fitted so they all do it.
    |8|7|R|B|3|0|V|L|
    vs executive
    Mar 2011
    merimbula
    thanks guys, its just a slight buzz doesnt bother me
    just thought it might be something major.
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    On a side note, mine makes a different sound when my fuel's low, like a more irritated buzz haha, so if you're low on fuel, expect it to sound wierd
    |8|7|R|B|3|0|V|L|
    VL Berlina 87
    Dec 2011
    South Australia
    if youve been running the car on below 1/4 tank of fuel too often it will do this to the fuel pump
    D22 St-r Navara
    Dec 2010
    perth
    mine did the normal buzz, it suddenly got louder and popped 10kms down the road. if in doubt just replace it
    VL Berlina 87
    Dec 2011
    South Australia
    the pump needs fuel to lubricate it in VLs so if your tanks running low it will run rough hence the rougher buzzing sounds
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    no it aint just the fuel over it deadens the actual sound of it..
    like a nagging missus until u put ur head under the water in a pool.. .... or hers...
  1. Rattle from the rear of car.
    By gatt_69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2009, 12:46 AM
  2. Rattle from Ls1 rear/underneath
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-11-2007, 09:22 PM
  3. rear speakers rattle
    By New2Holden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2006, 10:29 PM
  4. Rear seat rattle - sedan
    By B J in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2006, 06:44 PM
  5. Rear brake light rattle
    By G4orce in forum Car Audio
    Last Post: 08-08-2005, 09:39 PM
