Results 1 to 8 of 8
Thread: vl boost questions
    WK statesman 5.7, VS exec TURBO
    Sep 2005
    mornigton penisula VIC
    Default vl boost questions
    Hi there I have a high comp vl wagon. And its sits at around 7 or 8psi till it gets high in the rev range then drops to just under 5 psi
    Is this a normal thing?
    Also how much boost can I safely run with the standard turbo ecu, turbo injectors and standard turbo.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    I wonder if that indicates a leak somewhere?
    |8|7|R|B|3|0|V|L|
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    could be a boost leak, but it would do it at any rev's as the turbo is boosting in the low range to his set level.,, possibly the turbo is not keeping up on the demand the engine is sucking, which is weird. hence the boost drop. turbo running out of puff if u get my drift. motor is outflowing the turbo
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    OP, was the turbo stock & did you have issues with it previously or all of a sudden?
    |8|7|R|B|3|0|V|L|
    Sep 2005
    I'll check all the vacuum lines for leaks. There isn't an intercooler. It's a standard set up and it's always done it.
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Like Nath said maybe the turbo is on it's way out, I'm not too familiar with turbo's though
    |8|7|R|B|3|0|V|L|
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    id say 12 psi is maxing out, best putting it on the dyno. And me thinks u got a dodgey boost control.
  1. [WA] Wanted: Boost gauge,boost controller, ev6 36lb injectors and walbro in-tank
    By H1GHROLLR in forum Swap / Wanted to Buy / Trade
    Last Post: 11-06-2010, 04:42 PM
  2. 2 questions- l67 10psi upgrade boost reading and the s/c pulley bolt.
    By wana s' charge stock vt in forum V6 Development And Modification
    Last Post: 20-05-2010, 11:10 AM
  3. how much boost?
    By mat vsII in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-12-2009, 09:26 PM
  4. On-Boost
    By QWiK747 in forum General
    Last Post: 06-10-2008, 09:57 PM
