As says above how could a put a kill switch in VL
and possibly have the swith inside the car say under the centre console or somewhere
is it difficult?
nope
i have got a switch on my fuel pumps so when ignition is on my pumps dont prime therefore it just cranks and cranks... but not fire
i wired in between ignition signal wire to the relay for the fuel pumps and hid switch in the car(switch is a missile toggle switch with led)
so find something critical which makes the car run and switch inbetween..
another could be coil power. or something else in your fuse box...
so its just a matter of getting something like...
then cut any wire i please and chuck this in between yeah??
basically man yeah... as long as its a critical running subsystem.... dont knock it when ur driving though.. it will cut off ur engine...
yeah ur right, prob stash it a little away from general human movement
ive also got a fake LED but it stays on permanently even when car is running
wish i knew how to wire it to a ignition switch? somewhere?
yeah u have wired it to a constant power source thats all
do u know of a quick wire for to attach too
under the VL dash?
umm i wired my fake Led flasher to ignition. so when car is running its off when ignition is off it flashes.. it was a LED flasher from dicksmith $3
had 3 wires coming off it, Earth, Accessories and constant. i dont know about a normal LED with only earth and power. spose u could wire it in reverse to a relay so when off its connected and once relay is on its Disconnected. understand?
i did mine to the starter motor, so you dont have passengers flicking your nawwwws mid flightin my vl that was. best place aswell
funny that cos, im aware that if put a wire from starter u can start VL no key needed. I even got immobilzer and the hotwire still starts it grr
so hence need a kill
i personally no wanna be poppin the hood each time, but can see the how it be a good spot
i like the fuel pump idea
nah u just tap in to the wire there and run your new wires and switch inside the cabin. in your reach
nah i actually mean 'where are these actual wires? Im no good with electrics, am a handy man sure, but general knowledge of ignition wiring im a newbie
where is these accessible wires
right side of steering column?
or under the hood off battery?
or...
depends which approach u wanna take on,,,
it can be done around ignition..
me i did mine from fuse box(engine bay) and ran it through a grommet in firewall and hid it in car.
easy way start ur car.. pull out fuses/relays until u find one which kills the car(One at a time). say fuel pumps relay.... find the signal wire under fuse box to this relay socket and put in a switch so u make a "switched Loop"
lol tripper, with the kill switch im fine, any wire will take it, kinda funny
but i mean for the FAKE led wires. Where are the actual earth, power, constant wires in a VL, under dash? near steering ?
well OP was kill switch not ur fake LED
and u did not say u were sorted with ur kill switch..
in your ignition. or under the dash cluster the main loom u can tap into a wire there
Step 1: buy an LED.
Step 2: do it the right way and use a test light to find a power source that is hot when ignition on and off.
Step 3: connect + to wire, - to ground.
Step 4: watch it stay on.
Fake Alarm Links
Wire up Fake alarm Light
Blinking Red LED Car Alarm Light
Faux Car Alarm with Flashing LED
Kill Switch Links
How to install a kill switch in my VL
Installing a "kill switch"
Kill Switch
How to install a kill switch?
I did the easy part for you..
Google is good
Google does wonders
|8|7|R|B|3|0|V|L|
It's a VL. No matter how many fake LED's or kill switches you install if the thieves want it it's gone. If they can't start it they will just tow it.
