Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By jatsvl
Thread: Help Please, boot not opening!!
    1988 VL
    Oct 2011
    Mackay
    Default Help Please, boot not opening!!
    I bought a donor vl recently and the boot will not release. I want to check what kind of condition the boot lining is in. Does anyone know a way to get it open??
    VZ Wagon
    Jun 2011
    Brisbane North
    Boot release button in the glove box or use a key, otherwise, large wrecking bar, angle grinder, oxy torch, axe, or you could try removing the rear seat and going through there then use a screw driver on the latch.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Either the electric release or try and pry out the lock or use a screw driver
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    1988 VL
    Oct 2011
    Mackay
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    remove back seat, there are triangular holes behind the seat, get a torch and a long piece of wire with a hook on the end, reach in and hook the cable that is attached to the auto release and pull.
    this worked for me, then oil lock and adjust stricker. and maybe fix auto release.
    goodluck.
    edit; even with a crow bar it is very hard and lots of damage, best bet is to use a large screwdriver and gut and remove the lock.
    Nobody wants to play with me
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by jatsvl View Post
    goodluck.
    +1, don't use a crowbar, no way! Most cars have an area behind the rear seats where you can release the boot, as for getting the glove box button to work, I have no idea how they are wired etc.
    What about the key? Why won't that work?
    |8|7|R|B|3|0|V|L|
    vy2 clubsport
    Feb 2008
    adelaide
    1.its a donor car
    2.theres only two ways bust the lock or do what jats said or keep pushing poper fast with some one putting pressure on boot lid or pull the boot lid up whilst some ones popping button
  1. Boot not opening..
    By GMHCalais in forum General
    Last Post: 17-02-2010, 04:17 PM
  2. Help ... Opening boot/trunk of VXS
    By l0ui3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2009, 12:05 PM
  3. Boot not opening properly
    By fitz_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2008, 03:45 PM
  4. boot opening issue
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2008, 10:16 AM
  5. Boot Opening When Driving
    By jay_hman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2006, 02:16 AM
