Results 1 to 5 of 5
Thread: Difference between vl turbo and non turbo pistons. Pics attached.
    VL Series 200 , 85 VK Berlina, VL Executive Wagon
    Apr 2010
    Default Difference between vl turbo and non turbo pistons. Pics attached.
    Hi i just thought i would post this up to help the people who cant visually tell the difference between factory rb30 turbo pistons and the factory na pistons.
    As you can see the turbo pistons (from an A8 motor) on the left are dished and this is to bring the compression ratio down to 7.8.1.
    The pistons on the right are standard non turbo rb30 pistons which are in the majority of vl's and in all R31 skylines except of course those that have had a vl turbo motor conversion. As you can see they have a raised surface that is much the same shape as the vl turbo pistons except that it is raised not dished. In fact when i put the na pistons upside down on top of the turbo piston i think it nearly fit perfectly into the dished area. The comp ratio for rb30 non-turbo pistons is 9.0.1. hope this helps.
    Attached Thumbnails Attached Thumbnails Difference between vl turbo and non turbo pistons. Pics attached.-050.jpg
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Apr 2010
    Quote Originally Posted by VL_5SPEED View Post
    you dont need to change pistons when converting a n/a to turbo.
    I don't understand what you are directing that at.. was that just a general statement?
    Everyone knows that you don't need turbo pistons to convert your car to turbo. you will just have a higher compression turbo motor. this thread is just to show the visual difference of the turbo and non turbo pistons so anyone looking to buy a genuine turbo motor know what they're looking at if they have no idea.
    vy2 clubsport
    Feb 2008
    adelaide
    The engine number will determine if its a turbo motor.
    But good idea to show newbies to help explain and show newbies about turbo conversions and compresion ratio
    Apr 2010
    Quote Originally Posted by bow down View Post
    Yeah exactly. this should help since you have some people who are dodgy and rebuild blown A8 motors with na pistons, try to re-stamp A6 blocks, or try to advertise and sell series 2 na blocks as turbo motors for premium prices to those who are unaware of the factory stamping system.
  1. Ebay Turbo difference T3/T4 TO4E
    By RB30E+T in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-02-2011, 11:15 PM
  2. difference between n/a computer and turbo
    By dan_man31 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-04-2007, 07:57 PM
  3. turbo pistons v8
    By druthless in forum V8 Development and Modification
    Last Post: 21-05-2006, 10:35 PM
  4. VP V6 turbo pics
    By simc in forum V6 Development And Modification
    Last Post: 04-11-2005, 01:23 AM
