Results 1 to 3 of 3
Thread: rust around rear wagon window
    vl berlina wagon 6cyl
    Jul 2005
    Default rust around rear wagon window
    I have this common problem but the window surround stops me getting at the rust
    is there any way of removing the window surround so that it can be later replaced?
    its said that on the assembly line, the front and rear window surrounds were left in bare metal with no rust protection
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    I don't know much about the wagons, but are you talking about the seals? Throw up a picture so we can see the problem areas.
    if you can remove the seals, fix the rust, you can buy new seals from rare spares I think, and also ebay have them.
    |8|7|R|B|3|0|V|L|
    siroller is offline CAL 415
    vl sl s/w mx7 a8 -- vy acclaim s/w 3.8A
    Jun 2009
    push out the window with your feet and then when you have all of the rust fixed up take it to a window mob like windscreens obrien. they will fit a new bailey's channel rubber which is that rubber seal around the tailgate. otherwise if you mean the plastic skirts that go on either side they are just sickaflexed on. use a paint scraper, a long sharp knife or a screwdriver and cut / pry them off. you can put them back on or use a vb/c/h/k style wagon tailgate window seal which doesn't have the dress moulds, just a long seal all around it.
  1. VT Wagon Rear Window Wiper
    By 98vt series 1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2011, 10:34 PM
  2. Wagon rear window wiper
    By keza87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2010, 07:47 AM
  3. Rust in front+rear windscreen of wagon. How much can I expect to pay?
    By Captain Kermit in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-02-2009, 05:20 PM
  4. VR/VS roof leak (rear window + rust )
    By Trei in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 04:55 PM
  5. How to install a rear wagon window???
    By Mick Molloy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 12:46 PM
