Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Like Tree2Likes
Thread: My LE 87 rb30 VL :)
  1. #26
    vy2 clubsport
    Feb 2008
    adelaide
    Quote Originally Posted by 87RB30VL View Post
    I hate you!! Mine's only a series 1, but I looked at so many and they were all shit, so I had to settle with second best, well, I settled for the dog's leftovers, Auto, non turbo Executive
    The only reason I haven't turbo'd mine is that heaps of people who have converted theirs say "You have to do this, this, and this and bam there you go" but then other's who also converted say "nah man you need this, this, this, this, few of these, this this and maybe this, oh and this and this" and something that can be done for $800 by Joe Blow, becomes a $1,500 thing for Joe Doe.
    shit turbo conversion for $800.put me down for ten conversions lol.
    Hurry up and turbo it 87rb
  2. #27
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    hmm, ive heard that u get a t piece from the oil sender, i did that for my old tg gemini and ran the oil return down the dipstick LOL and kept the dipstick in the bay, pull hose out check oil put hose back dodgey but never failed. and some turbos dont need water so you can get away with just oil lines, the rest is a piece of cake.
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
  3. #28
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
  4. #29
    vn_v6's Avatar
    Aug 2009
    victoria
    first one to drop a dose makes the other upload a photo of their car with a chev badge...ULTIMATE EMBARASSMENT AT STAKE.
    deal?
  5. #30
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
  6. #31
    vn_v6's Avatar
    Aug 2009
    victoria
    time to sell my sisters TV! lol
  7. #32
    vn_v6's Avatar
    Aug 2009
    victoria
    nothing to do with the car but went on a cruise down princess and to beach road, meetup was at monash uni, and met alot of great people while having a great time checking out some sick cars, one was an xr6 with a turbo that had a mouth big enough to fit my head in 0.o and my head aint small LOL
    great turnout to
    small clip leaving monash
    VID 20111223 234030 - YouTube
  8. #33
    vn_v6's Avatar
    Aug 2009
    victoria
    PICTURE TIMMMME. red did the ignition timing and its spot on, i checked it with a timing light after but still wont tick over so doing cam timing next, i turned it off one day and it wouldnt start the next day and kept front firing.
  9. #34
    vn_v6's Avatar
    Aug 2009
    victoria
    setting the ignition timing on an rb30 without a timing light
    turn the bottom pulley (Crankshaft pulley) till you see a series of marks, there will be a little marker on the timing cover, line the first mark up with this little notch. your are either at top dead centre, or bottom dead centre, i placed a screwdriver down the spark plug hole of cylinder one and slowly turned the bottom pulley, if your at top dead centre the screwdriver gets pushed up, dodgey, but it worked for me! i checked my timing after this with a timing light and it is spot on 0 degrees!
    undo your dizzy cap, there is two phillips head screws, your bay should look like this after you get it off, dont take the leads off if you dont have to, saves u mixing them up.
    My LE 87 rb30 VL :)-img_20111223_192242.jpg
    now undo the bolt holding the dizzy to the head, and pull it out of your engine, you will see two dots on the gear that goes into the head, one deep one and another one to the right of it and slightly above it, and youl also see a line, what you do is you turn the dizzy to line up the shallow dot with the line on the dizzy itself. (mine is lined up on the wrong dot in the photo)
    My LE 87 rb30 VL :)-img_20111223_192336.jpg
    now when you put slide the dizzy back into the head, line up the line on the dizzy to the casting mark on the head. then gently push it in, the dizzy will turn about 1/4 turn as it slides in.
    My LE 87 rb30 VL :)-img_20111223_192404.jpg
    if you have done this correctly and your engine is at exactly top dead centre, this is the position your dizzy should be in. say hello to 0 degrees timing
    My LE 87 rb30 VL :)-img_20111223_192347.jpg
  10. #35
    vy2 clubsport
    Feb 2008
    adelaide
    if you only took dizzy out why are you messing with base timing for?
    and you can take leads of its a two second thing to put them back into correct position as the cap is numbered
  11. #36
    vn_v6's Avatar
    Aug 2009
    victoria
    i think the cam skipped a notch as its pretty loose. and my cap isnt numbered
  12. #37
    vn_v6's Avatar
    Aug 2009
    victoria
    what else could cause the car to run the not run after and front fire out the airbox? its getting fuel, spark and has compression seeing it ran before.
  13. #38
    vn_v6's Avatar
    Aug 2009
    victoria
    stripped out the interior today, cleaned the carpet gave the seats a good clean, suprisingly didnt find to much crap under it all. going to be fun putting it all back in tomorow! re did the dodgey wiring to the rear speakers done by previous owner. removing the lpg next weekend hopefully to
  14. #39
    vn_v6's Avatar
    Aug 2009
    victoria
    have been busy for the past week, finally found some time to tinker with the vl, havent hit the nail on the head with why its not starting anymore, but im waiting on a gates timing belt, a turbo mani, and a t3 once it starts, LET THE FUN BEGIN
  15. #40
    vy2 clubsport
    Feb 2008
    adelaide
    this thread is in the wrong section mate start one in the vl readers ride section or whatever its called
  16. #41
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by bow down View Post
    I second that, you'll get more people following/paying attention to it there.
    I'm keen on progress reports!
    |8|7|R|B|3|0|V|L|
  17. #42
    vn_v6's Avatar
    Aug 2009
    victoria
    ill start one tnite
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. Modifying standard RB30 to RB30 block / RB25 head + turbo... HELP!
    By 86VLred in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-09-2010, 12:07 AM
  3. skyline r31 rb30 coil on vl rb30 motor
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-04-2009, 10:30 PM
  4. vl rb30 into vh sl/e
    By clubsport_replica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-03-2009, 01:56 PM
  5. rb30/26 into vk
    By Evil_Monkey_148 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-03-2009, 03:27 PM
