Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By *uwishn*
  • 1 Post By Munz
Thread: Upgrading
    VR berlina
    Jun 2011
    sydney
    Default Upgrading
    I got a sedan VL, has anyone changed the throttle body to a bigger one? If so any change or Nar?
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Uhhhhh from memory someone mentioned using an xf t.b. or some shit, can't remember if it helped performance wise.
    Edit: Apparently there's no difference,
    Here's the link:
    XF Throttle Body Swap
    |8|7|R|B|3|0|V|L|
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    There is a bit of difference, but it is not huge, it's more so for the turbo's.
    it can help with pod filter, extractors and a 2 1/4inch exhaust.
    Nobody wants to play with me
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    no offence if the vl is a stock rb30 job, why bother?
    My VL Walkinshaw replica project
    VR berlina
    Jun 2011
    sydney
    VR berlina
    Jun 2011
    sydney
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    hey bud, exept for an exhaust (which i suggest a single 2.5in with a set of headers and a decent muffler) the best trick with an N/A rb30 is to advance the timing belt 1 tooth, i used to do this with all my N/A vl's and it does make a difference, also get a set of diff gears, you can get a set of 4.11s from a nissan pintara and the crown wheel and pinion bolt stright up to a vl
    that should wake it up a bit
    Going where no late model stato/caprice has gone before.... GAME ON!!
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Doesnt understand the point of doing mods to a "P Plate Legal" car...which would then make it illegal???
    But, if you really must.
    XF Throttlebody
    Extractors
    Timing
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Does adjusting the timing hurt the car at all, though? It's like, it's an NA, last thing you want to do is have the humiliation of destroying it
    |8|7|R|B|3|0|V|L|
    Sabbath''s Avatar
    Jul 2006
    You're going outside the factory specs of a 25 year old car. There's always the possibility. Eg. Melted pistons
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Skipping one tooth is supposedly 7 degrees..and have read its bad for the motor - too far advanced
    using an adjustable timing gear you can adjust up to 4 degrees
    Also ram some 90/100mm drain pipe from under the airbox and you'll have the cheapest and best flowing VL CAI on the market
    Ebay chip FTW lmao
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by Munz View Post
    Ebay chip FTW lmao
    |8|7|R|B|3|0|V|L|
  1. Upgrading ECU
    By Chuckster in forum V6 Development And Modification
    Last Post: 27-10-2007, 06:26 PM
  2. upgrading 202 to Vn V6
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2006, 06:22 PM
  3. Upgrading.....
    By Kytro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 02:36 PM
  4. vt upgrading
    By phoenix_984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2005, 08:30 PM
