I'm thinking of buying a Calais instrument cluster with white dials. and i was wondering how hard is it to wire up, i will be putting it into a vl exec (standard has, fuel, temp, speed and time), I'm pretty sure it doesn't come with anything but whats in this pic...
Thanks
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
pretty sure the loom already has all the outputs in it![]()
everything will fit and work except for the oil pressure.....you have to change the pressure switch to a sender and swap one of the wires in the big plug behind the dash.....
Click the scales.....you know you want to!!!!
yeah i have found out all the info, everything is the same, the plugs are all there but just used by the SL cluster all you have to do it change the oil sender otherwise it will give incorrect reading
thinking of doin the same thing, where did u get all the info for it? is it just a simple unplug and plug back in?
Simple unplug and plug in. Theres a wire you change in the cluster loom to get your oil readout.
search the tech article on www.calaisturbo.com
