Results 1 to 15 of 15
Thread: How hot do your VLs get?
    Pistol Guest
    Default How hot do your VLs get?
    hey guys, just wonderin how hot they get as mine never seems to, it only ever gets upto the second bar from the bottom and when you stop the car and come back half an hour later its basically cold again. I thought about the thermostat being stuck open but the book says that causes it to take time heating up where as mine gets upto the second bar in the first 5 mins odd with easy driving.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    mine gets past a quarter, looking on a third of the way up. its a v8 so it takes longer to get there but does get hotter. (same sized radiator with larger amount of cooling to do).
    albino1986 Guest
    mine gets up to about 3mm before halfway but then just sits there no probs with over heating though so thats always a good thing. dont need no blown head
    COOLANT IS YOUR FRIEND :P
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    mine always sits about 1mm over the second bar exept when i cracked my head... sat at HOT
    Going where no late model stato/caprice has gone before.... GAME ON!!
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i put aheavy duty rad in ,and only gos to 1st bar, with air on in middle of summer i think good investment
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    good idea, how hard is it to add a bigger radiator, just pick up one from the wreckers? im interested in doing it because a mechanic told me that that's the major problem for VLs, the head cracking
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    executive vt 5.0lt
    Feb 2005
    west suburbs
    my standard rad was leaking so i just took it to the rad repair shop and changed it for a bigger 1
    Pistol Guest
    Yer mine had a brand spanking new water pump on it when i got it tho it does get a little hotter when its being thrashed, thatd be normal tho. about due for a coolant change in fact, gonna need like 5 litres of antifreeze, the whole system takes 10 litres according to the book
    executive vt 5.0lt
    Feb 2005
    west suburbs
    yes i think the best collant helps too i use nulon aND LIKE I SAID it runs cool
    rimz81 Guest
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Mine used to run real cool but I think the timing may be out now coz it gets to 1/2 on hot days and in traffic
    ========My Statesman 20's Mafless and 3.9's========
    VRFURY's Avatar
    VRFURY is offline Just Nic
    VR Caprice
    Jun 2005
    Warragul
    Mine Had Always Sat On Half But My Radiator Sprung A Leak And Sat On 3/4 When I Got It Fixed It Now Sits On 1/4
    Behind every Great chick, Is a guy checkin' her out
    VZ Calais
    Aug 2005
    Mackay Qld
    Always sits on 1/2. If it gets higher { even 1 bar } then i check the level. But its usually 30 degrees here. Summer will be no fun!
    VS executive
    Jan 2005
    mine gets half. what is the temperature for that. in degrees?
    Half a carton and still going!!! Now thats Economy
  15. #15
    Pistol Guest
    wouldnt have a clue about what actual temperature they get to in degrees, the old mans car has the temp actually printed on it rather than plain bars, even the litres in the fuel tank but thats the europeans for ya. i had a look in the haynes book but that doesnt mention any numbers either. good question tho, wouldnt mind knowing myself
