Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Like Tree4Likes
Thread: Idle issue
    RobboVl's Avatar
    RobboVl is offline VL REPPIN'
    VL commodore
    Apr 2011
    Exclamation Idle issue
    hey all,
    I originally thoght this problem was an issue with the spark plugs, but i have since changed them and it is still there..
    okay, so when i pull up at a set of lights and let it idle i can feel sort of a miss-idle, and i can feel the vibrations through the car like the engine itself is jerking around (but not hard, you can just feel it.)
    And it is not timed it can stop for 5 secends then start and keep on doing it every 3 secends..
    Also it seems too stop when i put the car in nuteral..
    let me know what it could be, cheers! (:
    Lowerd O.G Cruiser
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Fuel pressure regulator problem.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vl berlina wagon 6cyl
    Jul 2005
    the correct way to set idle speed is shown in the workshop manuals and is complicated, you could try to find a VL workshop manual at a local library and photo copy details
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    clean ur AAC (Auxiliary Air Control)valve mate. its probably gummed up.. as well as u throttlebody. u can cheat and use carby cleaner...
    but i would part the plenum and flush it out with degreaser.. if u part ur plenum u will need a new gasket from plenum to intake runners
    whats ur idle RPM?
    should be around 750rpm u can bring it up slightly by adjusting the screw on the back of the plenum facing firewall.
    Dont adjust the throttle plate resting point.
    RobboVl's Avatar
    VL commodore
    Apr 2011
    cheers guys, ill have a play around with what use said!
    Yeah i have the gregories manuel and the owners manuel, and mny revs are sitting at about 850rpm.
    is that too much?
    Lowerd O.G Cruiser
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    RobboVl's Avatar
    VL commodore
    Apr 2011
    The problem still exists and it has gotten A LOT worse,
    its to the point were i cannot drive the car for more then 10minutes, it starts of fine then gets terrible.
    i have gotten a new dizzy and distributer cap. and it still happens.
    i did further inspection last night and i noticed the the spark plug number 5 clicks and you can see a spark jump out, i have checked the plug itself and it doesn't seem cracked. i tried to wrap the lead up with electrical tape to be a temp fix but that didnt work.
    If i dont fix the problem with a new set of leads i dont know whats next.
    let me know what i should do, cheers.
    Lowerd O.G Cruiser
    Vk 5LTR
    Oct 2007
    Melbune
    just curious on how to clean the aac valve and is there a gasket between it and the manifold
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    there is yes but should be ok.. make sure the pin is moving freely. u can go further when u remove the plenum to pull off the rear housing and clean in there properly. as a lot of blow by ends up in this area
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    a new set of leads will get it running on 6 cylinders again, does it blow out black smoke ? like its overfueling ? possibly coolant temp sensor, or cas but youve said you replaced that. also have you done a basic service on it ? fuel filter, air filter, etc.
    VB SL/E
    Dec 2008
    Quote Originally Posted by RobboVl View Post
    Next? New plugs.
    RobboVl's Avatar
    VL commodore
    Apr 2011
    cheers for all the replies!
    Quote Originally Posted by Sik_Cordz View Post
    to be honest i have no idea, i wasnt to comortable to fiddle around with things in there..
    Quote Originally Posted by detox_nath83 View Post
    i havnt cleaned up there yet, all i have done with the air intake is checked the filter and its fair too say i need a new one.
    tbh i dont know were to start cleaning it out, is there anything i can muck up in trying?
    and do i just get in there by undoing the bolys near the manifold?
    Quote Originally Posted by seans VL Calais View Post
    she is due for one really soon mate, and as for the smoke, no. just th smell of un burrnt fuel once turned off.
    Quote Originally Posted by VR38 View Post
    Next? New plugs.
    i got some new ones a couple of weeks ago, that is what i originaly thought it was..
    Lowerd O.G Cruiser
    RobboVl's Avatar
    VL commodore
    Apr 2011
    RobboVl's Avatar
    VL commodore
    Apr 2011
    Im still waiting for the leads in the mail..
    Is this the aac valve i should be cleaning out?
    If so i took it out and gave it a quick scrape with a brush.
    so the issue is still there but i notice it is only once it gets hot. i drive it for about 15minutes going about 40 to 80 ks. and it starts to do it.
    also it seems to do it a lot worse once i back down the revs. and it seems the only thing that stops it comking out up a hill is to hit the power button..
    any suggestions?
    Lowerd O.G Cruiser
  15. #15
    holden vl sl wagon
    Dec 2011
    gold coast
    mine has been doing the same this for about 6 months now u can feel it when she's idling its starting to piss me off ive cleaned aac , new plugs new leads im stuck???????
  16. #16
    few commodores
    Feb 2011
    victoria
    For cleaning in the above post when you have it off, blast inside where it came from with some carby cleaner also incase it's gummed up inside
    Air regulator? should only affect it when it's cold though, if the test in the pic below has an effect when it's hot then it's stuck open.
  17. #17
    VS-II Esteem
    Dec 2010
    Tasmania
    I had a prob when I first got mine off my brother. Virtually running on 4 cyl's. That transistor near the distributor! I had the earth wire just sitting there and one of the crank angle sensor wires to it was barely hanging. had to repair the connector and then went fine, until oneday my car died when low on fuel. Eventually found that it was a weak earth going to the pump and was running after that fine, although I know the pump's on its way out as it's making the idle rev's variate! Mightn't be this either, but replace fuel filter if it's old. Also, check the contacts on the AFM wires. I know these things will play up bad and even stop the car if the connection isn't good.
    Cheers!
    Jim.
  18. #18
    RobboVl's Avatar
    VL commodore
    Apr 2011
    cheers guys, ive cleaned out the aac and no luck, car does not start anymore, i have new leads on and that does not help.
    im stuck.
    Lowerd O.G Cruiser
  19. #19
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    r u getting spark??
    Fuel?
    compression?
    thats all u need so.. process of elimination man and c how u go. check back
    spew ur in Vic. would have helped u already
  20. #20
    RobboVl's Avatar
    VL commodore
    Apr 2011
    Thanks to detox_nath83 for helping me get the car started!
    Lowerd O.G Cruiser
  21. #21
    RobboVl's Avatar
    VL commodore
    Apr 2011
    i gave my local holden dealership a call and explained the problem and the suggested a new air flow meter, i picked up one on ebay last night. hopefully this solves the problem!
    Lowerd O.G Cruiser
  22. #22
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    no worries man
    hopefully its ur afm as these r a pain just like the CAS.. i had running issues today. so changed the CAS and all good... i was getting intermittent spark..
  23. #23
    RobboVl's Avatar
    VL commodore
    Apr 2011
    g'day guys.
    still no progress with this issue.
    afm didnt work and i have cleaned out and checked nearly all leads and plugs.
    it does seem a little better though.
    And i have noticed a sort of thud/rattle that SOUNDS like its coming from the timing belt area at the front of the bay.
    could this be a timing belt issue? and are they known too be fine when cold but stuffed up when hot? cheers.
    Lowerd O.G Cruiser
  24. #24
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  25. #25
    RobboVl's Avatar
    VL commodore
    Apr 2011
    pull the top timing belt cover off man and inspect the belt..
    this would not b responsible for this man,, u r missing something man..
    ill get on it mate, cheers!
    Lowerd O.G Cruiser
  1. a/c idle issue?!
    By CommodoreVS in forum General
    Last Post: 03-08-2011, 05:56 PM
  2. vs 5.0l idle issue
    By CommodoreVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2011, 10:19 AM
  3. VN Idle Issue
    By mrvdv in forum General
    Last Post: 22-04-2009, 07:32 PM
  4. Idle issue
    By cartoonwally in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2009, 08:10 AM
  5. VN SS Idle issue
    By ssn8r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2006, 02:06 AM
