Results 1 to 15 of 15
Thread: Vl wont start after replacing engine... Help please!!
    1988 VL
    Oct 2011
    Mackay
    Default Vl wont start after replacing engine... Help please!!
    Hey guys,
    My father and I have recently replaced the engine in my vl deciding it was easier then ripping the turbo gear off the old one (i didnt want to get rid of the turbo gear but the government hates P platers). Since replacing the engine the car refuses to fire up. The is no spark at the plugs. Weve cleaned the rotor button and dizzy cap and no moisture in crank angle sensor. Any suggestion on where to start looking for the loss of spark would be muchly appreciated. Also car has a 3TA ecu will that be a problem??
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by connorw View Post
    Hey guys,
    Yes I believe that is your problem! turbo ecu!
    Nobody wants to play with me
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    still doesn't explain lack of spark does it Jats??
    Try to spark off the coil at the front of the timing cover (little black box with lead going to dizzy)
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    few commodores
    Feb 2011
    victoria
    using your old dizzy or the one that came with the engine?
    power transistor, cas or a bad connection somewhere, checked fuses and relays and that you didn't bump something in the transplant?
    it will run with the turbo ecu, just not very well.
    Vk 5LTR
    Oct 2007
    Melbune
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    shouldnt b the 3TA.. dont really know, But might not like running the N/A injectors as the pulse widths are different cant really mix and match.. so try a N/A ECU
    as for the no sprak issue its either CAS or Coil as stated. try the CAS first though as they r tempermental bloody things.
    check the Loom plug where it plugs onto the CAS plug.. pull back the rubber boot and check the crimped wires are all still intact and have not corroded or snapped of during your transplant as this is a common problem anyways
    88 vl calais turbo
    Jan 2012
    bendigo
    1988 VL
    Oct 2011
    Mackay
    Hey guys found the spark and got it running ended up being the coil thanks a lot!!
    Next problem...
    where does this hose go to??
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Vl wont start after replacing engine... Help please!!-2012-01-12180439.jpgsee the diaphram, the hose on top of it goes to a steel pipe under the plenum, right next to it is another steel pipe, that is where your hose goes too!
    looks like a real pain to get to.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Vk 5LTR
    Oct 2007
    Melbune
    1988 VL
    Oct 2011
    Mackay
    its already connected there. i cant see anywhere it could connect that is close however the engine used to run on gas. could this be a left over tube from that??
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    have a look under the throttlebody there is a vac line there as well as near the AAC Valve is a vac line.. another is the Reg control solenoid down near the 6th cylinder intake runner near firewall. and front of Plenum near the PCV valve. have a look at the charcoal canister and trace some of the same diameter back to see if its come from around there as well
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  15. #15
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    there are 2 steel tubes under the plenum next to the fuel rail, one of them doesn't have a hose on the end of it.
    if you follow the hose from the fuel reg you will see where YOUR hose goes too.
    it is difficult to get to and you may have to take the top of the plenum off to get to it.
  1. engine wont start VT V6
    By mada Vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2011, 05:20 PM
  2. 98 - V6 VT wont start on first turn of engine
    By grafxworld in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2011, 11:23 AM
  3. Engine wont start
    By dorro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2009, 09:23 PM
  4. V8 wont start after replacing inlet manifold gaskets
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2007, 08:20 PM
  5. Engine wont start
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2006, 03:21 AM
