Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By nasty1
Thread: New to the world of the VL
    Vk 4.9 back door brock
    Jan 2012
    whyalla
    Default New to the world of the VL
    I got this white auto vl the other day because . . . . No idea why I did but I'm glad i did.
    So far she has been lowered with caster camber kits, front brake upgrade including master, race brakes n changed most of the brake lines to stainless (a perk of working in a brake shop).
    The Gbox has been having issues chosing gears and the speedo doesnt work. Could this be related to the speed sensor or the magnetic pickups in the speedo?
    few commodores
    Feb 2011
    victoria
    speedo is cable driven, the sensor on the speedo unit in the dash only really tells it to lock up the tcc at speed (fake 5th i've heard it referred as) and 4th, they're not an electronic trans
    how exactly is it having trouble choosing gears? slipping, dropping back when lightly accelerating? not changing at all? staying in a higher gear when you floor it without kicking down? a bit more detail pls, guessing you mean an auto trans not a manual gbox?
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by josh_e34 View Post
    Yeah we need more info dude, it could be absolutely anything
    |8|7|R|B|3|0|V|L|
    vl commodore
    Mar 2010
    N.S.W
    my speedo stoped working one day, hit a pretty nasty bump and it kicked in again, so check to see if its got loose wireing behind the dash cluster.
    vy2 clubsport
    Feb 2008
    adelaide
    few commodores
    Feb 2011
    victoria
    Quote Originally Posted by vlbrockyowner View Post
    as stated above, vl's are a cable driven speedo, no electronics all mechanical, the only electronics on them send a pulse for the ecu and/or trans comp/cruise control if fitted, lose wiring will not stop it from working
    pull the cluster out and move the car back n forwards to see if the inside cable is moving, if it moves it could be a faulty speedo unit or the cable wasn't pushed onto the cluster properly, they can be a bitch to clip on properly sometimes
    on the back of the cluster you'll see a small brass fitting inside a cast aluminium bit sticking out, give it a quick spin with your finger n look to see if the needle moves
    if the cable wasn't moving when you moved the car get under it and make sure it's connected properly to the trans, whilke you're at it get another person to watch in the car as you turn the bottom part of the cable to rule out a broken cable.
    can be an idea to spray some lube into the cable when you have the cluster out also, if the speedo works and jumps around it's usually caused by the cable binding from lack of lubrication
    when refitting the cluster don't do the 4 screws up to tight, the plastic has a tendancy to crack at the mounting points.
    vl commodore
    Mar 2010
    N.S.W
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    The clip retaining the cog on the trans output shaft may have come adrift, not sure what it's like on the VL boxes, but all the Trimatics i've pulled apart have had this issue.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. End of World
    By holdensupporter2005 in forum Jokes/Humour
    Last Post: 14-07-2008, 10:20 AM
  2. The End Of The World
    By TexasRealtor in forum Jokes/Humour
    Last Post: 20-01-2007, 04:18 PM
  3. World Cup
    By Andre's SS in forum The Pub
    Last Post: 29-06-2006, 09:15 PM
  4. Where in the world R U
    By Ho7den in forum The Pub
    Last Post: 18-09-2005, 06:41 AM
  5. it's a sad sad world
    By Garth in forum The Pub
    Last Post: 26-07-2004, 05:04 PM
