Results 1 to 6 of 6
Thread: vl indicator wont stay on
    holden vl sl wagon
    Dec 2011
    gold coast
    Default vl indicator wont stay on
    does anyone know why indicator wont stay on, in my vl . the left does but not right , does anyone knw how to take the steering colum cover off?
    cheers
    Vk 5LTR
    Oct 2007
    Melbune
    colum cover should just pry off. but be gentle. sounds like maybe the indicator stalk has had it. you can buy them new pretty cheap
    drewVHSS's Avatar
    drewVHSS is online now Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    column cover has 3 screws accessed from underneath
    indicator stalk is accessed from under the steering wheel.
    Steering wheel has to come off.
    Stalk may or may not be the problem, there is a plate that is moved by the stalk which is fixed under the mount for the stalk.
    I have spares of both if you are interested.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    take the steering wheel off, make sure to marke the column spline and and wheel so you can put it back on in the same spot.
    when the wheel is off you will see the problem, there is a plate spring with a bend in it that rests on the plastic housing (top for left, bottom for right) the plastic is probably worn and not allowing the spring to rest on it.
    Nobody wants to play with me
    88 vl
    Jan 2012
    Pottsville
    I had the problem to there is two springs that cancel/return the stick not the actual stick
    vl berlina wagon 6cyl
    Jul 2005
    remove steering wheel,in blinker switch there are 2 wire springs, one has probably broken, replace both springs, probably still available from a holden dealer, they are of different colours
    there is another flat silver metal spring that eventually breaks, dont know if this is still available anywhere
    the blinker unit can be repaired with new springs, doesnt need to be replaced
  1. s/w wont stay on!
    By kiwiboy86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 10:53 PM
  2. Boot wont stay closed only in the HOT
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-11-2009, 02:26 PM
  3. Boot wont stay up ??
    By stevevp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2009, 02:07 PM
  4. My SS seats wont stay DOWN?!?!
    By cookie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2005, 10:04 PM
  5. trimatic wont stay in top gear
    By evargyb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2005, 06:49 PM
