hey guys just trying to work out where to wire up the reverse lights. the gearbox has the sensors on it but no loom and my car is a factory manual. but i cant remember where i need to run the wires , to get the reverse lights working
isnt it the plug on the firewall man near the booster. like on the Autos?
hey mate yer i found one near the booster. but im not sure if thats it. its got a pink.black.green.grey wire. could this be it ???.
light green wire looks to be one of them, trying to find a better wiring schematic to confirm the other.
plug it into the loom and c man... should only fit if its right as all plugs r different to a degree![]()
I ran mine by splicing the actual wire heading to the reverse light found it under the door sill.... but this is straight power so I can't leave it in reverse when car is turned off or it will drain the battery.
Probably the dodgy way but it works
ill try those ideas guys. but i dont have the gearbox loom. so ill have to make one
