Results 1 to 4 of 4
Thread: Spark Plug Help
    vh sle
    Jul 2005
    sydney
    Default Spark Plug Help
    Im trying to change the spark plugs in my VL but not having any luck. I have the right tools and everything but the old plugs are in firmly. I've been told that i dont want to put to much pressure on them in case they break. Im pretty sure i'm doing everything right. The 5/8 spark plug socket fits fine. I am turning anti-clockwise, any suggestions? or should i just keep turning harder?
    VL RB30 Berlina
    Nov 2003
    try spraying some wd40 or sumthin down the hole......let it soak in for bout 5-10 mins.....may help also try using a t-bar instead of a ratchet.....a little harder to get in but puts the turning force on more evenly....
    Click the scales.....you know you want to!!!!
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    if they snap they snap. as long as nothing drops into the cylinder you'll be fine. I just changed mine and snapped three of them. you'll only stuff the thread by over tightening. try the WD40 and put more force into it. you'll be right.
    vl berlina wagon 6cyl
    Jul 2005
    the plugs are very hard to change, keep the plug spanner upright to stop breaking the insulators
    a universal joint in the extension helps on the centre plugs, be very careful and patient
    avoid cross threading the plug which is easy to do
    may help to put a length of plastic tube over the insulator to start in the thread by hand
    be sure to put some oil on the threads, graphite powder is said to be best by some?
  1. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  2. Spark Plug Gap???
    By markc3012 in forum V8 Development and Modification
    Last Post: 26-10-2005, 06:15 PM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. Best choice of spark plug VT 5L
    By RR5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 09:29 AM
  5. Spark plug gap???
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2004, 04:14 PM
